You should have gotten 12V at the orange wire regardless what position the ignition switch was in. It should be hot at all times with the power coming from the F.Pump Fuse (10 Amp). From the diagram below you can see that the wire is spliced at connector C203 which is the clear connector under the armrest. That may be where the problem is if you've checked that you're getting 12V at the fuse. That's one of the problems.
The other is that you should be getting 12V at the green/white wire for two seconds once the key is turned to RUN, but I'd troubleshoot the orange wire first since that will allow you to start the car with oil pressure.
