  deleting catalyic converter
deleting catalyic converter by ozzman333
Started on: 03-11-2014 01:30 PM
Replies: 2 (406 views)
Last post by: mitchjl22 on 03-12-2014 12:59 AM
ozzman333
Report this Post03-11-2014 01:30 PM Click Here to See the Profile for ozzman333Send a Private Message to ozzman333Edit/Delete MessageReply w/QuoteDirect Link to This Post
will running no catalytic converter in a 4.9 cause any problems,was told it will run rich plus other problems, anybody running no cat that can provide some info
Report this Post03-11-2014 02:10 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Probably some relevant posts in This thread.
mitchjl22
Report this Post03-12-2014 12:59 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think the 4.9 has a downstream o2 sensor, (correct me if wrong) and running a cat delete pipe, or just simply straight piping through the cat shouldn't cause any running problems. It will SMELL different... like an old 66 mustang, but other than that, there's no real adverse effects. You may want to check your state and local laws though. In ADA county here in Idaho if you don't have all the original emissions control systems in place that the car came with, it won't pass (in this case EGR, and CAT). Hope this helps,
-Mitch
My Car - 87' GT 3800sc
https://www.fiero.nl/forum/F.../HTML/121571.html#p0
