  Parking Brake left cable removal?
Parking Brake left cable removal? by FieroCat
Started on: 03-09-2014 06:37 PM
Replies: 2 (218 views)
Last post by: FieroCat on 03-11-2014 08:56 AM
FieroCat
Report this Post03-09-2014 06:37 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the process of removing the existing parking brake cables to replace them, removed the front already and that went fairly easily. However, the rear driver's side cable is proving difficult… there is a 3-pronged cable clip anchored into the frame right near the adjuster that only seems to be accessible from a little hole up on the side in the wheel well. I can't even see the clip, much less the tangs that need to be depressed to remove it.
Can't even get a tool in there to depress them! How do you remove this clip?
My Fiero: 1986 Pontiac Fiero GT, V6, 4-speed manual
Report this Post03-09-2014 07:36 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Small hole in frame allow you to break off lock tabs. Just use flat screwdriver.
FieroCat
Report this Post03-11-2014 08:56 AM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wasn't able to make any progress with the screwdriver, but after wrenching around on the outer portion of the clip with vise grips I was able to wiggle it enough to bust the tabs and yank it through.
