| quote | Originally posted by Gall757:
I would be more concerned about fuel pressure. Have you replaced the filter?
Use starting fluid to confirm spark is good. Watch out for flames shooting out of the Tb, however. If the car goes on starting fluid, figure the fuel delivery is not good. |
Fuel's coming from the injector in a conical mist, if I watch it with the air cleaner cover open. It's a little "clumpy" for what I'd like in a mist from an injector. Filter's new though. Starting fluid got an okay response from the engine, though it won't keep running on the gas. (White smoke from gas burnt.) Guessing water in the gas. Also - drained some gas directly into a clear container to check color, there's no way it's good. It looks like apple cider and does not smell remotely normal. Am going to attempt to drain the tank and fill with new gas, will try starting more tomorrow.
[This message has been edited by Ravant (edited 03-09-2014).]
