  Iron duke white smoke
Iron duke white smoke by Fadingaway
Started on: 03-09-2014 01:53 AM
Replies: 1 (252 views)
Last post by: theogre on 03-09-2014 09:37 AM
Fadingaway
Report this Post03-09-2014 01:53 AM Click Here to See the Profile for FadingawaySend a Private Message to FadingawayEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I believe I have found the source of the white smoke it is coolant and I believe it has something to do with my intake manifold. I forgot to re attach the coolant hose that connects to the bottom of said manifold and the white smoke was nowhere to be seen but oblivously coolant went everywhere. Does anyone know why the car would run perfect with coolant just flowing free out of the system does this mean there is a crack in the passage inside the manifold allowing it to leak inside the cylinders? Maybe a crack elsewhere causing this issue
Report this Post03-09-2014 09:37 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
because big "Leaking" coolant loose all system pressure.
likely, you have head or intake problems
