  Speed sensor harness
Speed sensor harness by LornesGT
Started on: 03-08-2014 11:42 PM
Replies: 4 (129 views)
Last post by: LornesGT on 03-09-2014 11:00 AM
LornesGT
Report this Post03-08-2014 11:42 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the engine pulled finally and took out the harness so I could clean the engine, Wow it's an oil mess.
Now on to the question. The speed sensor harness has two connector coming out of the bundle. One was tucked back on the the clip that hold the harness from getting damaged. The connect looks the same as the one that clips to the sensor. What should it be connected to?
Total ratings: 290
Report this Post03-09-2014 12:16 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Dk. Blue/Lt. Green wired connector goes to the 5 speed reverse switch. Not used on 4 speeds.
LornesGT
Report this Post03-09-2014 12:38 AM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you! So i have a 5 speed set off to the side for now.
[This message has been edited by LornesGT (edited 03-09-2014).]
Report this Post03-09-2014 06:56 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those were in the 86 4-speeds, in preparation for the introduction of the Getrag. Outwardly they appear the same, but if you look inside the tips, you'll see that one is female and the other is male. I don't remember which is which, but they're designed that so as not to plug into the wrong function. Imagine your backup lights getting brighter and brighter as you gain speed.
LornesGT
Report this Post03-09-2014 11:00 AM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I changed them to amber and made it look like after burners, I wouldn't mind.
