  ECM Questions
ECM Questions by ARKaiser
Started on: 03-08-2014 07:11 PM
Replies: 3 (592 views)
Last post by: theogre on 03-08-2014 09:24 PM
ARKaiser
Total ratings: 62
Report this Post03-08-2014 07:11 PM Click Here to See the Profile for ARKaiserSend a Private Message to ARKaiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pardon me for showing what little I know about the ECM but ...
1. are all Fiero ECM the same just with different proms?
2. if I suspect that I have a ECM problem would it most likely be the ECM itself or the prom?
The reason I ask is that I think the ECM is causing my hard/no start and bad idle problem since I have replaced ever sensor I can think of. I have what I believe to be a good ECM out of a running car and wondered if I can switch them out to verify my thinking that my problem is in fact a bad ECM.
BrittB
Report this Post03-08-2014 07:35 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you checked you fuel pressure yet? Also, double check the egr tube for cracks/ leaks. These are the two things I would look at first!
Report this Post03-08-2014 08:43 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The ECM and prom have proven to be one of the most reliable parts on a Fiero. You should examine fuel pressure, wires, plugs, rotor, ICM. connectors, and anything else that looks old, before you worry about the ECM.
you have a V6? Then you should trouble shoot the cold start injector.
Report this Post03-08-2014 09:24 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
L4
84-86 are same type ECM
87-88 are same ECM
See my Cave, Duke Quick Ref
Transmission matters too. All PROM/MEMCAL are program for trans type.
