  Steering Wheel retainer removel?
Steering Wheel retainer removel? by NightMare Cruiser
Started on: 03-08-2014 05:24 AM
Replies: 10 (389 views)
Last post by: Patrick on 03-08-2014 04:33 PM
NightMare Cruiser
Report this Post03-08-2014 05:24 AM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
What tools do I need to pull the steering wheel? Of corse a steering wheel puller. But what the other tool needed to get the retainer off??
Venomous
Report this Post03-08-2014 06:54 AM Click Here to See the Profile for VenomousSend a Private Message to VenomousEdit/Delete MessageReply w/QuoteDirect Link to This Post
If all you are doing is pulling the wheel then you just need the steering wheel puller. If you are going deeper into the column and need to remove the lock plate, then there is a tool for that as well. It threads onto the steering shaft and presses down on the plate to allow you to remove the clip that holds the plate in place.
NightMare Cruiser
Report this Post03-08-2014 08:00 AM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
In order to get my wheel off there's a retaining clip that holds the wheel on. I was told that GM did this as a extra safety precaution just in case the big nut came loose. I tried doing this once before, that's how I discovered the clip / ring.
It's a CAR, now drive it!!
http://s1277.beta.photobuck...50016365924013387734
After all the work, It's time to drive it!!
rogergarrison
Total ratings: 551
Report this Post03-08-2014 09:01 AM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, all you need is to take off the center cap, snap ring and nut. Then use the wheel puller. Its a good idea to take a marker, paint or fingernail polish to mark the top on the end of the shaft so your sure to get it lined up when you put it back on.
NightMare Cruiser
Report this Post03-08-2014 09:15 AM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
How do I remove the snap ring?
grkboy707
Report this Post03-08-2014 10:27 AM Click Here to See the Profile for grkboy707Send a Private Message to grkboy707Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do you mean the snap ring for the steering wheel lock plate (the little gear lookin thing that engages with a pin to lock your wheel)? If so, you need a cleverly named "Steering wheel lock ring remover tool". It has 2 prongs that push the plate down, while you turn a wing nut. I got mine at Advance Auto.
84fiero123
Total ratings: 325
Report this Post03-08-2014 12:46 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.amazon.com/Lisle...-Plate/dp/B0009OR956
That's a better one, they are available at all parts stores and even Harbor Fright if you want a real cheap one.
for the other clip just a small pick or hook will pop that off or even just a small flat bladed screwdriver.
Steve
[This message has been edited by 84fiero123 (edited 03-08-2014).]
Report this Post03-08-2014 02:44 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Take your pick...
rogergarrison
Total ratings: 551
Report this Post03-08-2014 04:10 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or you can start at one end with a very small screwdriver and pop it off being carefull it dont pop off all of a sudden and get lost..... Im talking about the one above the shaft nut that keeps it from unscrewing...not one on a locking plate...
NightMare Cruiser
Report this Post03-08-2014 04:14 PM Click Here to See the Profile for NightMare CruiserSend a Private Message to NightMare CruiserEdit/Delete MessageReply w/QuoteDirect Link to This Post
I went pepboys and borrowed a steering puller it had everything I needed in the kit. The clip I was having problems with was the locking plate clip. Thanks guys!
Report this Post03-08-2014 04:33 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
And how was that preventing you from removing your steering wheel?
I hope you realize you don't describe things worth a hoot.
