  Recall 86-C-16, rear cone clutch park brk
Recall 86-C-16, rear cone clutch park brk by Harold James Kie
Started on: 03-07-2014 06:22 PM
Replies: 2 (152 views)
Last post by: theogre on 03-08-2014 03:54 PM
Harold James Kie
Report this Post03-07-2014 06:22 PM Click Here to See the Profile for Harold James KieSend a Private Message to Harold James KieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is anyone familiar with what Pontiac did to resolve the recall on the emergency brake cone clutch? My 86 GT never had the recall taken care of and Pontiac Customer Service cannot find any information about it. Were there any parts replaced? If so, are the parts still available? What was done? Thanks for any help that anyone can give me, it is appreciated as always.
Report this Post03-07-2014 08:25 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found this. I included the Fram fuel filter, too because it's important. Should have been corrected by now, but some are still reporting fuel leaks.
Edited to replace dead links.
close RECALL Subject : AFTERMARKET FUEL FILTERS/FUEL LEAK
Report Receipt Date: MAY 19, 2006
NHTSA Campaign Number: 06E043000
Component(s): FUEL SYSTEM, GASOLINE
All Products Associated with this Recall expand
Details close
11 Associated Documents expand
Manufacturer: HONEYWELL INTERNATIONAL, INC.
SUMMARY:
CERTAIN REPLACEMENT FUEL FILTERS, FRAM BRAND NAME P/N G3727, WITH DATE CODES X52911 THROUGH X60801 SEQUENTIALLY OR X600141 AND A MEXICO COUNTRY OR ORIGIN MARKING ON THE FUEL FILTER HOUSING MANUFACTURED FROM OCTOBER 18, 2005, THROUGH MARCH 21, 2006, SOLD FOR USE ON THE VEHICLES LISTED ABOVE AND ON CERTAIN SCHOOL BUSES. (TO SEE THE SCHOOL BUS ENGINE SIZES, CLICK ON "DOCUMENT SEARCH" AND THEN "BUS APPLICATIONS"). THE CONNECTOR ON THE FUEL FILTER WAS NOT MANUFACTURED TO HONEYWELL'S SPECIFICATION. AS A RESULT, THE O-RING MAY NOT SEAT CORRECTLY ON THE FUEL LINE.
CONSEQUENCE:
THIS CONDITION MAY CAUSE AN INADEQUATE SEAL AT THE CONNECTION, POTENTIALLY LEADING TO A FUEL LEAK. IN THE PRESENCE OF AN IGNITION SOURCE, A FIRE COULD OCCUR.
REMEDY:
HONEYWELL WILL NOTIFY OWNERS AND REPLACE THE FUEL FILTERS FREE OF CHARGE. THE RECALL BEGAN ON OCTOBER 18, 2006. OWNERS MAY CONTACT FRAM CUSTOMER SERVICE AT 1-800-890-2075 (OPTION 1).
NOTES:
THIS RECALL ONLY PERTAINS TO AFTERMARKET FRAM FUEL FILTERS AND HAS NO RELATION TO ANY ORIGINAL EQUIPMENT INSTALLED ON THE VEHICLES LISTED. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Request Research
help
close RECALL Subject : EMERGENCY PARKING BRAKE:MECHANICAL
Report Receipt Date: APR 11, 1991
NHTSA Campaign Number: 91V055000
Component(s): PARKING BRAKE
Details close
1 Associated Document expand
Manufacturer: GENERAL MOTORS CORP.
SUMMARY:
PARKING BRAKE ADJUSTER FAILS TO OPERATE AND DO NOT WORK AFTER BRAKE PAD WEAR.
CONSEQUENCE:
PARKING BRAKES WILL NOT COMPLETELY HOLD A PARKED VEHICLEWHEN PARKED ON A SLOPE, CAUSING UNINTENDED VEHICLE ROLLAWAY WHICH COULD RESULTIN A VEHICLE ACCIDENT.
REMEDY:
REPLACE NONFUNCTIONING PARKING BRAKE ADJUSTERS.
NOTES:
SYSTEM: PARKING BRAKE.VEHICLE DESCRIPTION: PASSENGER CARS; FIREBIRDS AND CAMAROS WITH MANUALTRANSMISSIONS AND REAR DISK BRAKES AND FIEROS WITH MANUAL TRANSMISSIONS.
and this:
close INVESTIGATION Subject : REAR DISC BRAKES
Date Investigation Opened: JUL 22, 1988
Date Investigation Closed: AUG 30, 1991
NHTSA Action Number: EA88036
Component(s): SERVICE BRAKES, HYDRAULIC
All Products Associated with this Investigation expand
Details close
0 Associated Documents
Manufacturer: General Motors LLC
SUMMARY:
SUMMARY: CORROSION IN THE REAR BRAKE CALIPER PREVENTS AUTOMATIC ADJUSTMENT FOR PAD WEAR. THIS MAY EVENTUALLY CAUSE LOSS OF REAR SERVICE BRAKE AND PARKING BRAKE. GM HAS ADDED CORROSION PROTECTION AND CHANGED SPRING RATE TO CORRECT PROBLEM. SAME BASIC DESIGN USED ON ALL MODELS IDENTIFIED.
Request Research
help
Date Investigation Opened: FEB 21, 1990
Date Investigation Closed: JUL 31, 1991
NHTSA Action Number: C90001
All Products Associated with this Investigation close
Vehicle MakeModelModel Year(s)
CHEVROLETCAMARO1982-1986
PONTIACFIERO1984-1986
PONTIACFIREBIRD1982-1986
Details close
SUMMARY:
Notice the solution was to change the spring rate (stronger spring) and corrosion resistance (added or changed to a better seal to keep out the elements?)
It would probably be resolved by replacing the calipers with a new or rebuilt set. I don't think a rebuild kit would come with springs.
[This message has been edited by fierofool (edited 03-07-2014).]
Report this Post03-08-2014 03:54 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doc available thru www.michiganfieroclub.com/Tech_Tips.html
Is another/older version of GM 86-C-28, Fiero 84-86, Subject: Brakes, Handbrake Problem, Manual Transmission.
In a Nutshell
Old GM way... They replace rear pistons. GM parts are not available.
GM or DIY now... Replace whole rear caliper w/ rebuilt and hope got good units.
Read text at http://www.fieronews.net/fusion/downloads.php
Recall covers only stick cars but all cars (Not just Fiero) w/ same piston design have same problems. Firebird, 6000, and others including Seville rear calipers that many use to "upgrade" Fiero brakes.
[This message has been edited by theogre (edited 03-08-2014).]
