| | | quote | Originally posted by Merlinhaggard:
The sliders would be the tubes that the caliper bolts go through. The caliper slides back and forth on them. Dont know if this has anything to do with your problem. Are you talking about front only? If the front is dragging its probably the caliper piston not retracting. If its the rear, its probably the ebrake to tight.. Just thoughts. |
Yes the bolt sliders are lubricated. This is the rear calipers, I did not reconnect the e-brake system since that's what caused the original issue hence me replacing most of the system. Decided to wait on the e-brake cables since it's an auto.
On the right front, I do have some half drag. I can rotate, half the rotor is normal drag, half is heavy, so the rotor is out of round. I will be checking the bearing fitment and again torque to spec.
Thank you for the reply.
