  $100 brake upgrade ?
$100 brake upgrade ? by fireboss
Started on: 03-01-2014 09:39 PM
Replies: 5 (610 views)
Last post by: fireboss on 03-03-2014 08:44 PM
fireboss
Total ratings: 58
Report this Post03-01-2014 09:39 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have done the booster upgrade will your sunroof still fit in the front compartment.....
EDIT TO ADD..
The sunroof stays in one piece..
[This message has been edited by fireboss (edited 03-01-2014).]
Report this Post03-02-2014 09:24 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
It should as the plastic support bracket is only pushed up about 1/4" higher with the larger booster. If there is interference, you could cut off the tab that holds the wind deflector, as this will allow the booster to fit without raising the plastic support bracket.
From this thread: https://www.fiero.nl/forum/Forum2/HTML/121747.html
I was able to take a couple of pictures of the available clearances:
The S10 booster body is 1.78" larger in diameter, so the body should be .89 closer to the frame rail and the plastic support for the sunroof air deflector. So I fabbed up a little stack of washers that approximate thickness, wrapped them in electrical tape and then test fitted them:
Plenty of room for the body, but the flange on the booster body will interfere:
The booster will also interfere with the plastic piece, but it is quite flexible and will move up the needed amount:
fireboss
Total ratings: 58
Report this Post03-02-2014 02:30 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just what I needed thanxs....
DimeMachine
Report this Post03-03-2014 06:26 PM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just cant say enough about this mod - Best mod for $100!!!
84/87 NB, 3800SC, E-85, VS Cam, 2.8 Pulley, 4T65E-HD, HP Tuners, AEM Wideband, Regal GS Gauges, S-10 Brake Booster. 1/4 mile -11.85 at 114mph
seajai
Total ratings: 51
Report this Post03-03-2014 08:01 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree! I also installed the braided SS brake hoses as well, what a difference! This upgrade as saved me a couple of times from the trouble my right foot always seems to cause.
fireboss
Total ratings: 58
Report this Post03-03-2014 08:44 PM Click Here to See the Profile for firebossSend a Private Message to firebossEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got it going on my 87GT,with 12" rotors and 88 brakes,with braided lines
