  Highest setting on the fan not working
Highest setting on the fan not working by jimbolaya
Started on: 02-28-2014 06:26 PM
Replies: 8 (234 views)
Last post by: Marvin McInnis on 03-06-2014 03:26 PM
jimbolaya
Total ratings: 114
Report this Post02-28-2014 06:26 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
86 GT. Settings 1-3 work on the fan when I have the heat on. Is this the blower motor or something in the intrument panel?
Jim
Fiero_Fastback_Freak
Report this Post02-28-2014 07:55 PM Click Here to See the Profile for Fiero_Fastback_FreakClick Here to visit Fiero_Fastback_Freak's HomePageSend a Private Message to Fiero_Fastback_FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine does the same thing so I would like to know as well
seajai
Total ratings: 52
Report this Post02-28-2014 07:59 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
The top setting on the fan bypasses the resistor block and runs through the high speed blower relay under the hood. Check for power in and out of the relay. Power for the high speed blower comes from the fuseable link. More than likely your high speed blower relay is bad.
[This message has been edited by seajai (edited 02-28-2014).]
jimbolaya
Total ratings: 114
Report this Post03-01-2014 06:21 AM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by seajai:
<snip>
Thanks seajai. I'll let you know when I get it sorted out.
Jim
Justinbart
Total ratings: 119
Report this Post03-01-2014 06:32 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had the same problem and just fixed it. The relay was bad.
Turbo 3800 E85 F23 5spd spec5
10.91@133.1
jimbolaya
Total ratings: 114
Report this Post03-05-2014 02:20 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got in the relay today, and it is fixed. Thanks to everyone.
Jim
84fiero123
Total ratings: 325
Report this Post03-05-2014 09:39 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Actually I think its called a rheostat, if it is the coil thing I am thinking of, if not forget what I said.
Steve
fierobug
Report this Post03-06-2014 02:23 PM Click Here to See the Profile for fierobugSend a Private Message to fierobugEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info. Just before I put it away I noticed no hi speed. Drove me nuts. Thought it was vacuum problem with switch. Will check it out. It would be nice when and IF IT EVER WARMS UP!!!!!
FIEROBUG!!!!!!!!!!
Marvin McInnis
Total ratings: 227
Report this Post03-06-2014 03:26 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 84fiero123:
Actually I think its called a rheostat, if it is the coil thing ...
Nope. That's a multi-tapped power resistor. It might sometimes be called a ballast resistor.
A rheostat is a continuously-variable, usually wire-wound, power resistor that's value can be changed easily by turning a knob or moving a slider.
[This message has been edited by Marvin McInnis (edited 03-06-2014).]
