  Exploding Alternator
Exploding Alternator by Fiervette
Started on: 02-27-2014 10:04 PM
Replies: 8 (618 views)
Last post by: Fiervette on 03-03-2014 10:44 AM
Fiervette
Report this Post02-27-2014 10:04 PM Click Here to See the Profile for FiervetteSend a Private Message to FiervetteEdit/Delete MessageReply w/QuoteDirect Link to This Post
It didn't really explode, just shed all of the plastic fins. I have an 86 GT with a LS1 swap that was installed using an Archie kit. It has the stock SI type alternator. Problem is that I have had 2 of them break off all of the plastic fins for the fan. The first one failed shortly thereafter. I am just waiting for the second one to die. The first was replaced under warranty but I don't want to have to change it every few weeks. I asked Archie and since he never heard of this problem, he didn't have any advice. I don't think it is hitting anything and don't see any damage on the firewall or nearby components. The only thing I can figure is that the engine pulley on the LS motor is quite a bit larger than the v6 so the alternator turns to fast. The Fiero alternator pulley is smaller than the Corvette alternator pulley that came with the engine.
Has anyone ever had this happen? Any advice?
This weekend I am replacing the struts, plus changing the cradle and rear control arms to poly. While I was at it, I was thinking about doing the CS alternator upgrade. I was going to use one from a 90's big block truck that has the larger 6 groove pulley. This also has metal fins on the fan. I am hoping this will solve the problem but I am seeking advice if there is a better alternative.
Thanks in advance -
James
hookdonspeed
Total ratings: 131
Report this Post02-27-2014 10:47 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
if you think its over-rev'ing then replace the pulley on the alt with a larger one? also maybe try some metal blades?
Orig88GT-NC
Report this Post02-27-2014 11:58 PM Click Here to See the Profile for Orig88GT-NCSend a Private Message to Orig88GT-NCEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have had this problem before, installed (3) rebuilt alt before I got a decent one. Each had inturnaley exploded within a day or two of installation. Just kept returning them until I got one that lasted the last 10 years so far. Just bad rebuilds.
The were from NAPA
My sympaties been there.
tesmith66
Total ratings: 135
Report this Post02-28-2014 08:13 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is this a 12Si with the smooth front external fan behind the pulley? Is the belt rubbing the fan?
1986 SE Aero coupe.
fierosound
Total ratings: 286
Report this Post02-28-2014 08:46 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check to see if the pulleys ARE lined up properly.
I'd swap in a CS130 alternator. They were on the 88 Fiero.
https://www.fiero.nl/forum/Forum2/HTML/127379.html
I have them on my GT and my Indy.
Calgary time/temp
[This message has been edited by fierosound (edited 02-28-2014).]
Report this Post02-28-2014 09:49 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Metal fans won't fix over rev'ing problem. Plastic fan is early warning the alt can/will die soon.
Using CS130 won't help either.
You need correct alt pulley for crank pulley.
alt to crank pulley size ratio sets Alt's RPM.
If use small WP pulley then OE for this engine then will cause problems is cooling system.
WP will have problem from cavitation, even destroy the WP, by over rev.
if both are small... then maybe use smaller crank pulley.
Phil
Total ratings: 154
Report this Post02-28-2014 10:26 AM Click Here to See the Profile for PhilSend a Private Message to PhilEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should try to keep the max alt rpm at 15000 rpm. To figure that out multiply your motor rpm times your pulley ratio.
dematrix86gt
Report this Post02-28-2014 11:03 AM Click Here to See the Profile for dematrix86gtSend a Private Message to dematrix86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
For tight installs and higher rpm motors we use a honda alt converted to one wire, their about the side of a orange and 1/3 the weight of a gm. you can buy them fairly cheap and they take heat better than a v6 gm alt. and they will spin the higher Revs no problem too. and any Gen/ALT rebuilder can change the amperage to your choice for a couple 20s
Fiervette
Report this Post03-03-2014 10:44 AM Click Here to See the Profile for FiervetteSend a Private Message to FiervetteEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for all of the replies and advice. I think I will go with my original plan and install a CS130 type from a truck. This will have a larger pulley and a metal fan.
-James
