  V Belt Issue
V Belt Issue by FieroJosh1993
Started on: 02-26-2014 11:13 PM
Replies: 5 (125 views)
Last post by: theogre on 02-27-2014 04:20 PM
FieroJosh1993
Report this Post02-26-2014 11:13 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys, so i have an issue with my V belt. I have a 2.5L automatic. When Im driving to school in the morning with lights on everything is fine until I get to a stop light, when the car starts to idle as I wait for the light the lights get dimmer and the voltage gauge on goes from 15v to 12 or lower. When I start to go again the belt squeals until i get up the rpm. The belt is tightened all the way, as far as it can go. I do have a coolant leak on, i think its around the water pump. Im watching it to find it 100%. I think it may be effecting the belt. but if you guys can point me in the right direction that be great.
dematrix86gt
Report this Post02-26-2014 11:18 PM Click Here to See the Profile for dematrix86gtSend a Private Message to dematrix86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
put a UV dye in your water pull it inside turn off all the lights and turn a UV light on and Youll deff see where its leaking. it will glow bright.
Total ratings: 461
Report this Post02-26-2014 11:48 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The belt could just be worn out.
tebailey
Report this Post02-27-2014 08:55 AM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or a bad bearing in the water pump could be causing the belt to slip.
FieroJosh1993
Report this Post02-27-2014 02:53 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
I will look into it. I couldnt find the coolant leak yet. I will try the UV dye later this week. I did replace one hose today and I have another ordered. I replaced the belt as well. It was stretched out as far as it could go and was falling apart due to the coolant. new belt is working well but I need to fix the coolant leaks so it doesnt happen again.
Report this Post02-27-2014 04:20 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Coolant Will kill any belt. Coolant have additives that lube/protect WP seal.
1. fix the leak
2. Clean All pulleys. tips See my Cave, Serpent Belt
3. use New belts
