  Trunk corner rust
Trunk corner rust by Fiero_Fastback_Freak
Started on: 02-26-2014 06:18 PM
Replies: 6 (1152 views)
Last post by: Gall757 on 02-27-2014 08:09 PM
Report this Post02-26-2014 06:18 PM Click Here to See the Profile for Fiero_Fastback_FreakClick Here to visit Fiero_Fastback_Freak's HomePageSend a Private Message to Fiero_Fastback_FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the best way to fix this properly and preventing it from happing again?
Report this Post02-26-2014 06:39 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The problem with fixing that rust is that it's not the problem. It is just an indicator that there is probably more rust on the frame rails that should be fixed. You should remove the plastic wheel well liners and look at the rear frame rails, which support a lot more than the trunk.
Report this Post02-27-2014 05:42 PM Click Here to See the Profile for Fiero_Fastback_FreakClick Here to visit Fiero_Fastback_Freak's HomePageSend a Private Message to Fiero_Fastback_FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I planed on taking the inner wheel wells off and checking the frame rails as well, but what do I need to do in order to fix this problem?
fieroaddicted
Report this Post02-27-2014 05:46 PM Click Here to See the Profile for fieroaddictedSend a Private Message to fieroaddictedEdit/Delete MessageReply w/QuoteDirect Link to This Post
cut out the bad, weld in new metal. I have a tiny hole in mine in this area, and the lower frame rail on this side was gone where the rear cradle bolt goes in. Judging by the pic above, you will probably be in for a similar problem. Good luck !
troy
Report this Post02-27-2014 06:33 PM Click Here to See the Profile for Fiero_Fastback_FreakClick Here to visit Fiero_Fastback_Freak's HomePageSend a Private Message to Fiero_Fastback_FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Troy how did you fix the frame rail?
Old Lar
Total ratings: 214
Report this Post02-27-2014 07:48 PM Click Here to See the Profile for Old LarSend a Private Message to Old LarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cut the rusted frame rail out and weld in new metal.
Report this Post02-27-2014 08:09 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
