  Help Locating Coolant Leak
Help Locating Coolant Leak by Pegasus88GT
Started on: 02-23-2014 06:44 PM
Replies: 5 (164 views)
Last post by: Pegasus88GT on 02-24-2014 10:38 AM
Pegasus88GT
Report this Post02-23-2014 06:44 PM Click Here to See the Profile for Pegasus88GTSend a Private Message to Pegasus88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 88 GT 2.8L has had a very slow coolant leak for a while. Now when the car is running I can see a very steady drip coming from under the car. I got under it and tried to locate it and took some pics. I was initially thinking the water pump went bad even though I replaced it 1.5 years ago and it only has 5,000 miles on it. By the looks of the leak I'm thinking it isn't the water pump. From underneath the car the dripping is coming from between oil filter and the A/C compressor. I couldn't tell if what it was dripping off of was the rear manifold or a hose. It is directly under the second bolt that goes into the manifold. Thoughts on what it could be? It only leaks when running. Thanks!
Dodgerunner
Total ratings: 323
Report this Post02-23-2014 06:57 PM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
It might be your gasket between the timing cover and the block. When you change the pump if you don't keep the timing cover tight since the WP bolts are part of what holds it tight you can cause the gasket to start leaking.
A common place is right behind the large coolant hose (from the radiator ) coming off the water pump. The gasket between the block and timing cover gets very narrow there and can be a place it leaks. It's hard to spot but you will often find the back side of the large coolant hose wet because the coolant will leak out and run down the coolant hose then drip off on the AC and other area.
[This message has been edited by Dodgerunner (edited 02-23-2014).]
dematrix86gt
Report this Post02-23-2014 07:04 PM Click Here to See the Profile for dematrix86gtSend a Private Message to dematrix86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use a UV dye in the coolant . Turn out the lights turn the UV on and youll deff see it!!!
84fiero123
Total ratings: 325
Report this Post02-23-2014 11:42 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ayup, you can get the dye and light cheap enough and it will save you a lot of time.
Steve
Report this Post02-24-2014 09:42 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
That area?
WP, Timing Cover or hose? Maybe.
Can have freeze plug or head gasket is bad.
Try the dye as above.
Pegasus88GT
Report this Post02-24-2014 10:38 AM Click Here to See the Profile for Pegasus88GTSend a Private Message to Pegasus88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the replies! I guess I'll give the die a shot this coming weekend and hopefully have everything in check soon.
