  install 3800SC problem *couple of questions
install 3800SC problem *couple of questions by Lou6t4gto
Started on: 02-23-2014 12:22 AM
Replies: 15 (268 views)
Last post by: IanT720 on 02-23-2014 02:16 PM
Lou6t4gto
Report this Post02-23-2014 12:22 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, got the 3800SC "into" the 87 GT, I had to cut away about 1/2" off the bottom of the pass side trunk hinge. But , problem is: the supercharger Idle "pulley" is still touching the "Torque ROD" for that hinge ! Do I have to "LOSE" that torque rod ?? What have you other guys done about that ? and I did end up "raising" the floor of the trunk about 6" for room for the Muffler (1995Firebird). also, the 87 GT, only has 1 Heater Hose that" attaches to the Engine", (the other is "T" into the lower cooling hose. which "outlet" on the engine do I use for the 1 heater hose?? Thanks
Lou6t4gto
Report this Post02-23-2014 01:40 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
upon further "Inspection", I see that Both Torque arms must be removed. 1 hits the tensioner pulley, the other comes down on the SC belt. Time for trunk lid struts.
MstangsBware
Total ratings: 459
Report this Post02-23-2014 02:02 AM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lose both rods.....Unsure why u r having to cut the pass side hinge..What mounts r unusing and what SC tensioner?
Lou6t4gto
Report this Post02-23-2014 02:11 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
using Fieroflyer mounts (Altered GP I think he said) with stock 2.8 rubber mount, and stock tensioner. sit level, and clears everything else. are you thinking the mount is too Tall ? I'd post pictures, but PIP keeps saying my pictures are too large, and I can't figure how to make them smaller.
Report this Post02-23-2014 08:29 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
On the few that I have done, the passenger side lift strut had to be removed but the drivers side barely cleared on autos and interfered on stick installs. With the 4T65eHD, all was good until the SSIC went on. On no install did the hinge bracket need to be trimmed.
Report this Post02-23-2014 09:04 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have never had to trim anything, even when using an intercooler.
I have seen several installs where the decklid really had to be butchered because the mounts put the drivetrain too high.
MstangsBware
Total ratings: 459
Report this Post02-23-2014 12:27 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Same here....Unless the Buick SC tensioner is trying to be used...They usually hit the firewall or are very close..
Justinbart
Total ratings: 119
Report this Post02-23-2014 12:37 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
You shouldn't have to cut or remove anything.
Turbo 3800 E85 F23 5spd spec5
10.91@133.1
Lou6t4gto
Report this Post02-23-2014 01:18 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
EVERYTHING is bone Stock on this 97 Rivera engine/trans (all rebuilt) sitting on Fieroflyer's Mounts. no low mount, all tensioners stock. hope these pictures show up
Lou6t4gto
Report this Post02-23-2014 01:25 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
Member since May 2008
Lou6t4gto
Report this Post02-23-2014 01:27 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
it says everything is working, but instead of my pictures, all I get is the X in a box, right clicking won't work !
Lou6t4gto
Report this Post02-23-2014 01:28 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
Lou6t4gto
Report this Post02-23-2014 01:29 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
katatak
Total ratings: 82
Report this Post02-23-2014 01:40 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've done 2 - one in an 86 and one in an 88 - both Autos. No interference with the hinge and or torque rods on either one. I'll see if I can find some pics.
Belt routing
86 Install
88 Install
[This message has been edited by katatak (edited 02-23-2014).]
MstangsBware
Total ratings: 459
Report this Post02-23-2014 01:48 PM Click Here to See the Profile for MstangsBwareSend a Private Message to MstangsBwareEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't see pics...
[This message has been edited by MstangsBware (edited 02-23-2014).]
IanT720
Report this Post02-23-2014 02:16 PM Click Here to See the Profile for IanT720Send a Private Message to IanT720Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry didn't really read through but... I know I had to swap my Bonnie S/C belt tensioner for a Grand Prix one I believe. Maybe same for buicks? I removed the torsion rods but never had to cut anything else...
