  wire for toggle switch?
wire for toggle switch? by maybenot
Started on: 02-22-2014 06:01 PM
Replies: 6 (117 views)
Last post by: maybenot on 02-23-2014 07:54 AM
maybenot
Report this Post02-22-2014 06:01 PM Click Here to See the Profile for maybenotSend a Private Message to maybenotEdit/Delete MessageReply w/QuoteDirect Link to This Post
hi guys,
i am putting in 2 toggle switches. which wire is better to control with the switch-pos.or neg.?
if it matters, it is a simple single throw on/off switch. one would control a dash cam and the other a medium size rear yellow strobe bar.
thanks.
gtoformula
Report this Post02-22-2014 06:30 PM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless the terminals are marked or there are instructions that indicate otherwise it shouldn't matter. The switch just completes the current path.
maybenot
Report this Post02-22-2014 09:12 PM Click Here to See the Profile for maybenotSend a Private Message to maybenotEdit/Delete MessageReply w/QuoteDirect Link to This Post
thats what i figured, but i didnt know if there was a preferred way. for instance maybe you dont use pos because it has current and neg would just be completeing it? if thats even a thing, :confused
[This message has been edited by maybenot (edited 02-22-2014).]
logical1
Report this Post02-22-2014 09:37 PM Click Here to See the Profile for logical1Send a Private Message to logical1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yea that is true on more complex setups, but on a setup like that you will be fine. Just remember to place an inline fuse between the line you tap before it gets to your toggle switch.
maybenot
Report this Post02-22-2014 10:00 PM Click Here to See the Profile for maybenotSend a Private Message to maybenotEdit/Delete MessageReply w/QuoteDirect Link to This Post
got it, thanks
Marvin McInnis
Total ratings: 227
Report this Post02-23-2014 01:59 AM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless there is a specific reason not to, always place the switch on the "hot" side of a circuit, as close to the power source as possible. If you place the switch on the "ground" side, the entire circuit upstream of the switch will be "hot" at all times, even when the switch is open (i.e. "off"). The general wiring layout should be:
Power Source --> Fuse or Circuit Breaker --> Switch --> Load --> Ground
[This message has been edited by Marvin McInnis (edited 02-23-2014).]
maybenot
Report this Post02-23-2014 07:54 AM Click Here to See the Profile for maybenotSend a Private Message to maybenotEdit/Delete MessageReply w/QuoteDirect Link to This Post
see, thats why i asked. thank you for the preferred way.
