  GM Vehicle? Courtisey light problem
GM Vehicle? Courtisey light problem by James Bond 007
Started on: 02-21-2014 11:58 AM
Replies: 5 (149 views)
Last post by: dobey on 02-21-2014 06:02 PM
James Bond 007
Total ratings: 263
Report this Post02-21-2014 11:58 AM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
My other car is a 2000 Pontiac Grand Prix. The interior lights (all the courtesy lights, includeing the door) take an unusual long time to shut off, about 5 minutes. Any budy have this happen on a GM vehice and whats the fix? Thanks.
[This message has been edited by James Bond 007 (edited 02-21-2014).]
Report this Post02-21-2014 04:18 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you're concerned about it draining the battery swap to LED bulbs, they dont use much juice
But reallly, otherwise i dont know whats up with it.
rogergarrison
Total ratings: 551
Report this Post02-21-2014 05:05 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think a lot of cars now are just programed to to that on their own. Ive had different cars that take different times. My Sebring takes 3-4 minutes to shut off after I open the door unless the key is on, then goes out immediately. My headlites are the same way, but I have to turn the key off with the lites on, then turn off the lite switch. The headlites then stay on 3-4 minutes before they go out.
Report this Post02-21-2014 05:27 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, Car could have BCM etc program to keeps lights on for X seconds to minutes.
If you start the car, does shut off light sooner? If so BCM etc programed.
A few lights on for minutes should not be a problem. If that does, problem is elsewhere... dieing battery, etc.
James Bond 007
Total ratings: 263
Report this Post02-21-2014 05:32 PM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
No, after starting the car they stay on as Im driveing.Eventually they go off.Just seems like they should go off when the engine is started or go off sooner.
dobey
Total ratings: 371
Report this Post02-21-2014 06:02 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
They should go off when you turn the key to the "Accessory" or "Run" positions. If they don't, it sounds like it might be a wiring issue. If you have remote entry, they should also go off more quickly, when you lock the doors with the remote.
But, this thread belongs under Other Cars instead.
