  pre 88 front crossmember
pre 88 front crossmember by lordbg0205
Started on: 02-16-2014 02:58 PM
Replies: 3 (231 views)
Last post by: Knight on 02-19-2014 08:42 PM
lordbg0205
Report this Post02-16-2014 02:58 PM Click Here to See the Profile for lordbg0205Send a Private Message to lordbg0205Edit/Delete MessageReply w/QuoteDirect Link to This Post
Alright guys, I'm about to replace the front crossmember on my 87GT. Are all front crossmembers the same from 84-87? Also fierostore no longer carries these. Know any good places to find one. Mine ovaled out the upper arm holes. I do know a great welder but he probably wants 200 to fix it. I'm sure I can just replace it. Any ideas?
Rodrv6
Total ratings: 76
Report this Post02-16-2014 04:19 PM Click Here to See the Profile for Rodrv6Send a Private Message to Rodrv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
As far as I know, 85-87 are the same. 84's may be slightly different, but will bolt up.
Rod Schneider, Ball Ground, Ga.
"You can't have too many toys!"
1988 Fiero GT
1987 Porsche 944S
1987 Corvette
1966 Porsche 911
2001 Chrysler 300M
Van's RV-6 airplane
KissMySSFiero
Total ratings: 111
Report this Post02-16-2014 04:36 PM Click Here to See the Profile for KissMySSFieroSend a Private Message to KissMySSFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have on that I just pulled. It currently is sitting in my shed.
Do you need control arms? The ones attached to it have ball joints with about 10k miles and poly bushings.
this was off my own car that I parted due to rust on the frame rails. This was a replacement front cross member i put on my GT while I was in Germany.
It has drop spindles on it and 11.25 big brakes, but I also have the stock spindles that have the rotor machined for the big brakes too.
The poly bushings all have grease fittings installed so you'd never have to worry about them being squeaky.
Only reason i'm not using them is I now have an 88. So all parts that could be swapped over were.
I also have koni front shocks. The rears were installed on my 88.
SSFiero@Aol.com
[This message has been edited by KissMySSFiero (edited 02-16-2014).]
Knight
Report this Post02-19-2014 08:42 PM Click Here to See the Profile for KnightSend a Private Message to KnightEdit/Delete MessageReply w/QuoteDirect Link to This Post
You have a pm
