  Behind the inner door handle there is a black plaster shield
Behind the inner door handle there is a black plaster shield by notwohorns
Started on: 02-16-2014 08:55 AM
Replies: 4 (303 views)
Last post by: notwohorns on 02-17-2014 10:46 AM
notwohorns
Report this Post02-16-2014 08:55 AM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Behind the inner door handle there is a black plastic plate, or shield that covers the view through the door handle that hides the inner door. It is a little smaller than the door handle. When I removed my inner door panel, it just fell out. How is that installed? Thanks
BrittB
Report this Post02-16-2014 10:40 AM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you take a picture of this piece?
88FieroGT TTops
Report this Post02-16-2014 10:48 AM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know what you are talking about--the filler piece of black plastic fits onto the metal pate that the handle is part of. There should be little plastic tabs the fit into recesses on the metal bracket that has the actual door handle-it just sits on it and gets trapped when you put the outer plate back on
Pat Jones
BrittB
Report this Post02-16-2014 10:53 AM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's the part that the screw goes onto that is found on the outside of the door skin under the trim strip. The little tang thing goes towards the handle as it sides inro the bracket which is actually attached to the door frame. That little SOB makes it a bear to reinstall the doorlock clip!
notwohorns
Report this Post02-17-2014 10:46 AM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
TTops, that is it. Thanks everybody for replying.
