  LS4 fuel pump problems
LS4 fuel pump problems by solracs
Started on: 02-15-2014 10:46 PM
Replies: 3 (470 views)
Last post by: Darth Fiero on 02-17-2014 12:08 AM
solracs
Report this Post02-15-2014 10:46 PM Click Here to See the Profile for solracsSend a Private Message to solracsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 88 fiero.. Fieroking did my harness.. I talked to him a lot about this but we still can figure out whats the problem.
The engine cranks but fuel pump wont prime or run..
The problem i have is that the ecm is not sending the signal to the relay..
What could be causing this? bad ecm or bad wiring?
wiring was done wrong 2 times but right now as far as i know the fuel pump relay is wired right and it does crank the engine when i hit the switch..
any help plz!!!!!!!!!
Darth Fiero
Total ratings: 361
Report this Post02-16-2014 04:02 AM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the check engine light coming on when you turn on the ignition?
What year/make/model of car did the ECM come out of? (so I can look up wiring diagrams)
OVERKILL IS UNDERRATED
solracs
Report this Post02-16-2014 03:09 PM Click Here to See the Profile for solracsSend a Private Message to solracsEdit/Delete MessageReply w/QuoteDirect Link to This Post
it is from an 06 impala SS. It has the E40 Ecm. Service num. 12596679
i thought i would be the vats but joe has dissable it and still has same problem
Darth Fiero
Total ratings: 361
Report this Post02-17-2014 12:08 AM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does the check engine light turn on when you turn the key on?
Are you getting constant 12v + power to ECM pin C1-20 and TCM pin 32?
Are you getting key-on 12v + power to ECM pins C1-14, C1-18, and C1-19; as well as on TCM pins 11 and 31?
-ryan
