  Fastback Tail light LEDs
Fastback Tail light LEDs by ANAM427
Started on: 02-12-2014 10:39 PM
Replies: 4 (1421 views)
Last post by: masospaghetti on 02-14-2014 11:12 AM
ANAM427
Report this Post02-12-2014 10:39 PM Click Here to See the Profile for ANAM427Send a Private Message to ANAM427Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone know anything about LED tail light options for the fastback? I know TLG Auto sells a kit for the notchback but it states its for notchback only. Any thoughts?
Adam
2001 BMW 325ci
1988 Pontiac Fiero GT
craigsfiero2007
Total ratings: 71
Report this Post02-12-2014 10:50 PM Click Here to See the Profile for craigsfiero2007Send a Private Message to craigsfiero2007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Read this thread, especially the last page.
https://www.fiero.nl/forum/F...1/HTML/093014-4.html
ANAM427
Report this Post02-13-2014 09:13 PM Click Here to See the Profile for ANAM427Send a Private Message to ANAM427Edit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for the info!
Report this Post02-14-2014 09:30 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
You really just need an LED version of the stock bulb, and an LED flasher, unless you want to change the style of light or have cool sequential stuff.
Pontiac Fiero Car Stock Incandescent Light Bulb Size Guide:
Low Beam Headlight Bulb Size: H6054
High Beam Headlight Bulb Size: H6054
Parking Light Bulb Size: 2057
Front Turn Signal Light Bulb Size: 2057
Rear Turn Signal Light Bulb Size: 2057
Tail Light Bulb Size: 2057
Stop Light Bulb Size: 2057
High Mount Stop Light Bulb Size: 889 or 906
License Plate Light Bulb Size: 194
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 194
Rear Side Marker Light Bulb Size: 194
Ash Tray Light Bulb Size: 70
Dome Light Bulb Size: 906
Step/Courtesy Light Bulb Size: 168
Trunk/Cargo Area Light Bulb Size: 168 or 561
Instrument-General Light Bulb Size: 168 or 194 or 37
Hi-Beam Indicator Light Bulb Size: 194
Seat Belt Indicator Light Bulb Size: 194
Brake Warning Light Bulb Size: 194
Automatic Transmission Indicator Light Bulb Size: 194
Directional Signal Indicator Light Bulb Size: 194
Then there is things like this:
Q: Is there any difference between incandescent 1157 and 2057 tail/turn signal bulbs?
A: Yes the difference is wattage. On some cars this can trigger the Lamp out light to come on. Other than that it should work without problems.
masospaghetti
Report this Post02-14-2014 11:12 AM Click Here to See the Profile for masospaghettiSend a Private Message to masospaghettiEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got some of the red "SMD" style bulbs for the stop/brake lamps and they seem about as bright as stock 2057. You have to use red LEDs though, white ones will lose a lot of brightness through the red lens.
The 1-watt wide angle red LEDs work well for the "pontiac" logo.
