  when installing the 3800SC 1987 GT
when installing the 3800SC 1987 GT by Lou6t4gto
Started on: 02-12-2014 04:57 PM
Replies: 6 (182 views)
Last post by: Lou6t4gto on 02-12-2014 11:43 PM
Lou6t4gto
Report this Post02-12-2014 04:57 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
When "initially installing" the 3800SC, (1987 GT) ,can the original 6 cyl Fuel pump be used to "ONLY' start it ?? will it have enough pressure just to "TEST" that everything else is functioning ?? (drop the tank and put the right pump in" after I know" it will start ??) Thanks
jonathan2014
Report this Post02-12-2014 06:13 PM Click Here to See the Profile for jonathan2014Send a Private Message to jonathan2014Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes the original fuel pump to the 2.8 will start it. But I would not recommend going into boost did it on my car ran ok at idle. hope it helps.
darkhorizon
Total ratings: 451
Report this Post02-12-2014 06:39 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
no problems.. the pumps are basically the same the 2.8 is just slightly smaller.
Justinbart
Total ratings: 119
Report this Post02-12-2014 07:02 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why?
Turbo 3800 E85 F23 5spd spec5
10.91@133.1
hnthomps
Total ratings: 51
Report this Post02-12-2014 08:55 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you decide to eventually replace the fuel pump, I am running a 3800 SC Series engine with a DW200 fuel pump. It is quite, fairly reasonably priced, and has a "no fault" three year warranty.
Nelson
darkhorizon
Total ratings: 451
Report this Post02-12-2014 08:58 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
gotta know the motor runs!!! thats why!!!
Lou6t4gto
Report this Post02-12-2014 11:43 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Exactly ! I already Have the correct new pump, just would like to know it'll actually RUN before I drop the tank. I have the 3800SC and 4t65e HD on an extra cradle (ready to go in), so if I run into problems, the 2.8 can be "slipped right back in". Thanks
