Update System
  '88GT suspension questions
'88GT suspension questions by notaguru
Started on: 02-12-2014 10:48 AM
Replies: 2 (153 views)
Last post by: Blacktree on 02-12-2014 01:14 PM
notaguru
Report this Post02-12-2014 10:48 AM Click Here to See the Profile for notaguruClick Here to visit notaguru's HomePageSend a Private Message to notaguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
This '88GT has 40k miles on it, but spent many years stored in the sun. I finally got the engine running and smogged (!!!!), and cleaned up most of the interior items that were damaged by sun and heat. The mechanical work should be finished before it's repainted.
It's somewhat noisy - clattering - on bumps, and the cornering is not what it should be. Inspection shows cracked and deteriorated bushings.
Hopefully the experts here can recommend a solution - stock, urethane, delrin, etc. and make other suggestions.
Thanks
Report this Post02-12-2014 01:07 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The clattering is the sway bar end links. Kind of like a tamborene.
Blacktree
Total ratings: 350
Report this Post02-12-2014 01:14 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The recommendation would depend on how you drive the car, and your personal preference. For example, if you're going to use it as a track toy, then go with Delrin bushings and bushing-less sway bar endlinks (like Rodney Dickman's "zero lash" endlinks). For a street performance car, urethane all around. For a daily driver or boulevard cruiser, rubber control arm bushings with urethane endlink bushings. These are just examples; they aren't set-in-stone rules.
