| | | quote | Originally posted by Jecklen16:
Sorry it's hard to explain. When clutch pedal is released (not pressed) the car doesn't seem to care about what gear your in as far as revs go it just keeps revving in accordance with how hard I press on the gas. When I press the gas pedal halfway then the revs drop and the car starts accelerating at a normal rate. I just purchased it a couple months ago and have mainly been working on the engine and electrical system. |
That IS hard to understand.
I think you can disregard my previous post I thought you said "clutch pedal half way" but you said gas pedal.
Are you saying you can let the clutch out and it just keeps idling in gear, and the car doesnt go forward until you push the gas pedal down at least half way? That seems like it is slipping unless the rpms are "high"...
Sundowner is probably right on what to check. If the slave is stays pushed out (it pushes out when you press down the clutch pedal) it would keep teh car from moving forward. But I'm not sure how more rpms would make it change. Open your decklid and have a friend push the clutch pedal in and out and watch for the slave to move.
