  EGR System
EGR System by Coachstewart
Started on: 02-11-2014 09:14 AM
Replies: 4 (849 views)
Last post by: Patrick on 02-11-2014 04:39 PM
Coachstewart
Report this Post02-11-2014 09:14 AM Click Here to See the Profile for CoachstewartSend a Private Message to CoachstewartEdit/Delete MessageReply w/QuoteDirect Link to This Post
In my State, because of the age of the car, emissions systems aren't inspected.
Has anyone removed the egr system and cats ?
Report this Post02-11-2014 09:19 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Removing the catalytic converter is very common in non-emissions areas. Some also remove the EGR valve and block off the manifold and intake. You would need to also remove the EGR solenoid and disable tyhe function in the ECM else you will have a constant Check Engine Soon light any time you drive. There is always some heated debate over the possibility of damaging the engine if the EGR system is disabled, so I won't make any comments on that.
Report this Post02-11-2014 01:18 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the Forum!
If you anticipate better performance with the EGR system removed, you may be disappointed. Sometimes repair can be a lot cheaper than removal.
Try EGR remove in the search function. Be sure to click + archives.
[This message has been edited by Gall757 (edited 02-11-2014).]
Report this Post02-11-2014 04:22 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, I didn't notice the first post status. Welcome. Great bunch of people here. You should enjoy.
If you aren't aware, yet, check out NCFiero.Com Great bunch of folks there, too. Many are also members here on PFF.
Report this Post02-11-2014 04:39 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the forum.
It would be very helpful if you mentioned the year and engine of your Fiero in your posts. I see the assumption has already been made that you have a V6. If you have a 4-banger, the advice will be differnent (in regards to EGR solenoids, etc).
