  CS130 conversion for an 84 2.5
CS130 conversion for an 84 2.5 by ag9123
Started on: 02-10-2014 04:38 PM
Replies: 7 (277 views)
Last post by: Blacktree on 02-12-2014 12:28 PM
ag9123
Report this Post02-10-2014 04:38 PM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi,
I see tons of threads on upgrading a V6 alternator from SI to CS130 but nothing for the 2.5.
Is there any difference in the procedure that I need to be aware of?
It looks to be a two wire set up so i know I'll need to adapter plug...
1984 Indy Fiero
[This message has been edited by ag9123 (edited 02-10-2014).]
Total ratings: 568
Report this Post02-11-2014 01:03 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
basic same thing.
also See my Cave, Alternator Sense
fierosound
Total ratings: 286
Report this Post02-11-2014 02:07 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by theogre:
basic same thing.
Yup. Put one on my Indy's engine - fits the stock alternator brackets.
Calgary time/temp
Blacktree
Total ratings: 350
Report this Post02-11-2014 03:01 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just FYI, the 88 Fiero V6 uses a CS alternator. It uses a serpentine belt, whereas yours uses a V-belt. So if you swap pulleys and grab a wiring pigtail, you should be good to go.
[This message has been edited by Blacktree (edited 02-12-2014).]
ag9123
Report this Post02-11-2014 04:44 PM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the quick responses guys! best forum I've ever been on... I don't think there's any Fiero issue that hasn't been discussed in here
1984 Indy Fiero
CowsPatoot
Total ratings: 84
Report this Post02-11-2014 05:12 PM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
As the others have said....it is as simple as swapping the pulley and getting the wiring pigtail. I used a stock alternator from an 88 v6 in my 84. Do not try to go with one of the oversized ones (CS140)....it will hit the intake on the 2.5.
The swap was pretty straightforward...mine is an auto, so it had to come out the top. The upper alternator bracket isn't that difficult to remove....but don't even think about removing the lower one, those bolts also hold the engine mounting bracket.
Total ratings: 568
Report this Post02-11-2014 07:29 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just FYI, the '87-88 Fiero 4-cyl uses a CS alternator. It uses a serpentine belt, whereas yours uses a V-belt. So if you swap pulleys and grab a wiring pigtail, you should be good to go.
No. 87-88 Fiero 4-cyl alt has wrong front case. It has 120° mount points.
Old L4 use same alt as V6, 180° mounting, shown above. Need correct V pulley.
Blacktree
Total ratings: 350
Report this Post02-12-2014 12:28 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, thanks for the correction.
