Unsure how I missed this, but there's a noticeable gap on the passenger side between fender and hood. Any ideas what the issue is, does the plastic warp over time or can it be adjusted? Luckily I have another hood, rear deck and side panels that came with the car I have to pick up in KY.
It looks like your hood isn't aligned. there are 4 bolts, 2 on each bracket that connects the front of the hood to the car that will need to be loosened so that you can move the hood around. Be careful though, you can spend hours trying to get everything perfectly aligned. When it is aligned correctly though, the gap should be smaller and the hood will close easier. Mine was out of alignment for a while and was a pain to close
Hard to tell without seeing the whole hood all the way around. Looks to me like it just needs the passenger side latch adjusted down, maybe even knocked down some. Judging from the headlite shot, and the close fit between hood and nose there, at some time, its been hit in the right front and knocked back. It either pulled the latch part in the hood down some (maybe even out of the hood panel), or buckled the part where the latch is, up. You might even need to pull the bumper cover off and bend the mounting out towards the front to get more clearance there too. Like I said, looks like the bumpers been pushed back into the hood.
need pics of the whole hood, and underside of hood and the firewall where latch is to be more sure.
Mine fits like that too. I haven't been able to adjust it to fit better...gave up. Be sure to mark the bolts before you try any adjustments. This way you can return to where it is now, if you're not able to make it better.
Check for front end damage. The PO of my 88 must have hit something. I found some bent metal underneath. There is a "too large" gap along the front. Maybe 1/4 inch too big, but you can adjust the hood at the hinge to align it.
Boy y'all were all over this. Funny story, false alarm, I left the old radiator cap laying on that side after last weekends coolant flush. I love easy fixes
