  3800sc Belt Routing
3800sc Belt Routing by MFord1993
Started on: 02-07-2014 10:26 PM
Replies: 1 (255 views)
Last post by: sco77 on 02-07-2014 11:54 PM
MFord1993
Report this Post02-07-2014 10:26 PM Click Here to See the Profile for MFord1993Send a Private Message to MFord1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I've been wanting to rebuild the top end of my 3800sc, but before I pull the supercharger off, I need to decide on how to route my belt. I think I've got it now though. I'm going to be running an electric waterpump, no A/C. So I figure its not really worth having 2 belts. Here is what I think I'm going to run with.
The alternator isn't fully mounted yet, and I flipped the idler bracket and drilled it out just bigger than 3/8". I picked up another pensioner pulley to replace the idler with as it's about an inch smaller. I figure this way should work. The alternator will have the least wrap, and even then, its almost half.
So what do you guys think? Don't hold back, I can take it
Current Vehicles;
1984 Fiero SE (Saved from Crusher, 47k original miles)
1985 Fiero GT "Red GT" (3.4 rebuilt from a 95 Camaro)
1988 Fiero "Black Fiero" (Mid 3800sc swap/ restoration)
1988 Fiero GT "The GT" (Original silver, currently winterized)
1989 Olds Cutlass Cierra "Grandpa"
[This message has been edited by MFord1993 (edited 02-08-2014).]
sco77
Report this Post02-07-2014 11:54 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Generally a bad idea to go with 1 belt if you don't have to, the supercharger and the alternator are both high resistance devices when they are under load, but looks like that should work fine.
86 Fiero GT 4spd - L67 swap: VS cam, GenV
98 GTP - Some mods
