  88 Brake Master Cylinder Bore Size
88 Brake Master Cylinder Bore Size by 2002z28ssconv
Started on: 02-03-2014 07:45 PM
Replies: 4 (794 views)
Last post by: 2002z28ssconv on 02-10-2014 08:59 PM
2002z28ssconv
Total ratings: 51
Report this Post02-03-2014 07:45 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
As much as I hate to start a new thread, I have been searching for hours now... I figured it would have been covered before but I sure can't find it.
Car - 88 Fiero 2.5 Auto - 100% factory stock.
Problem - Leaking rear seal on brake master cylinder.
I purchased a reman from AZ (P/N - M2357)
A knowledgeable Fiero friend told me to watch for them selling me one with the wrong bore size.
So I am verifying... maybe...
From the little I was able to find here on PFF in threads about the differences between the Fiero and S-10 masters, the Fiero master has a 0.944" bore diameter. That equates to 24mm.
The spec sheet AZ printed out for me says that their master has a 1.414" bore. So right off the bat, I think I have the wrong master.
However, I went to Advance as well as O'Reilly's and any master they brought up said 24mm/36mm.
So I'm on a hunt for what the correct bore size should be.
I suspect that the chamber for the front brakes is 24mm and the rear is 36mm. Dose anyone have the no longer available shop manual? Perhaps it would say in there. I lost my downloaded version with my last hard drive failure.
Either way I figure I'll be taking the old one apart and comparing it to the new one. I just want to try to make sure I get the right part before I tear the car apart again.
[This message has been edited by 2002z28ssconv (edited 02-03-2014).]
Blacktree
Total ratings: 350
Report this Post02-03-2014 10:31 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know the bore size offhand, but can send you the FSM when I get a chance.
Also, are you going to the CFF club meeting on Thursday? I'd like to chat about cyl heads, if possible.
2002z28ssconv
Total ratings: 51
Report this Post02-04-2014 06:11 AM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll be there. Need a set of heads?
My gmail is chjesthe, if you want to email the FSM.
Thanks
Blacktree
Total ratings: 350
Report this Post02-04-2014 06:33 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually, I just need one cyl head. And if you want, I can put the FSM on a CD. That will save it from hard drive crashes.
2002z28ssconv
Total ratings: 51
Report this Post02-10-2014 08:59 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
For closure... I didn't get to take the new MC apart. Once I got a chance to work on the car I was in a hurry to get it in and bled. The new Dorman one is aluminum. The old one was iron. I have the same Dorman MC on my other 88 GT and it's brakes are good so I installed it.
But it seems to be working okay.
