  blower
blower by adifferentlook
Started on: 02-02-2014 10:33 PM
Replies: 5 (191 views)
Last post by: Patrick on 02-03-2014 11:57 PM
adifferentlook
Report this Post02-02-2014 10:33 PM Click Here to See the Profile for adifferentlookSend a Private Message to adifferentlookEdit/Delete MessageReply w/QuoteDirect Link to This Post
vent. Is it suppose to be there or do i need to close it up. I know i need to build a box for the defroster vent. If anyone has pictures, i would appreciate it.
also does anyone know where the obd plug is for a 84 fiero, 4cyl.
Thanks
Anthony
picture of the hole
https://www.dropbox.com/sc/...heiacg6da/wjisf7y-RT
Report this Post02-03-2014 04:03 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't know what you mean about whether it's "supposed" to be there. I'm kind of disoriented by your picture, but shouldn't your dash/ductwork be sitting on that?
It's in the center console beside the cigarette lighter behind the panel.
PIP is the best way to post images here.
[This message has been edited by Patrick (edited 02-03-2014).]
Report this Post02-03-2014 07:29 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is the air intake for the HVAC blower. There is no door over the opening, but a piece of screen will keep "visitors" from gaining access during storage.
You have been busy with the cutting equipment, what are you up to?
ALDL plug should be behind the cigar lighter trim plate on the console.
adifferentlook
Report this Post02-03-2014 04:25 PM Click Here to See the Profile for adifferentlookSend a Private Message to adifferentlookEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, I am building a lambo kit car it has been stretched, so now I have to put a bar across that hole, I want to make sure it didn't need to be closed before I weld the bar.how do I do pip , for pictures
tebailey
Report this Post02-03-2014 05:18 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck with pip, never could get it to work for me.
Report this Post02-03-2014 11:57 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's all explained at the link I gave you.
