  Thoughts on ClutchMasters clutch on f23?
Thoughts on ClutchMasters clutch on f23? by mattman134
Started on: 01-30-2014 05:18 PM
Replies: 2 (170 views)
Last post by: fieroguru on 02-01-2014 07:51 AM
mattman134
Report this Post01-30-2014 05:18 PM Click Here to See the Profile for mattman134Send a Private Message to mattman134Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am doing a 3800sc/f23 swap and I don't feel like spending $565 for a SPEC clutch. Anybody ever use a ClutchMasters FX series clutch on their F23 without hitting the bellhousing? I want to get the FX400 6-puck spring clutch kit since I am producing around 330chp/400ctq
http://www.nopi.com/dsp_par...hp?vnopinum=365+0702
mattman134
Report this Post01-31-2014 01:03 PM Click Here to See the Profile for mattman134Send a Private Message to mattman134Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Report this Post02-01-2014 07:51 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am using a ClutchMaster 6 puck clutch in the SBC/F23 I am working on. Its completely different in that the flywheel isn't as deep into the bellhousing (due to the adapter plate thickness), so clearance to the differential boss isn't any issue. However, I can't comment if it will work with a 3800/F23 setup.
However, with all the run-arounds and delays to get the clutch, I would never recommend then as a clutch supplier. This was the 2nd ClutchMasters clutch for this car, so all they had to do was lookup the previous order and make/ship one just like it. However, numerous times when they said the clutch shipped, and it hadn't, they came back a week or two later and requested more info (like confirming the spline count on the input shaft). I didn't really keep track of the exact timeline, but it was something like 6 weeks for the clutch disk and 3-4 weeks for the pressure plate.
I guess Spec spoiled me. I call them up, order the clutch by part # and its at my house in 3-7 days.
