  Headlight Motor Control - Old School
Headlight Motor Control - Old School by Cajun
Started on: 01-29-2014 03:01 PM
Replies: 10 (579 views)
Last post by: mitchjl22 on 02-06-2014 01:42 AM
Cajun
Report this Post01-29-2014 03:01 PM Click Here to See the Profile for CajunSend a Private Message to CajunEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have wanted to post this for some time now but for whatever the reason I just never got around to it. Quiet sometime ago I upgraded the headlight motors on my ’86 GT to Style II headlight motors but have never been able to get them to function properly. I have gone thru several headlight control modules, none of which have been 100% functional. Needless to say I was growing tired with having the headlight motors not functioning properly. So, until such time I locate a used headlight motor control module I decided to come up with a semi-permanent solution. In my quest to design something I decided to go old school. i.e. the same type of control circuit that is used in the 1965 Corvette. Oh, by the way, my ’86 GT shares the stable with my other ride, a ’65 Corvette Stingray.
To make the project happen I acquired the following items:
2 – 87-88 Headlight Motor Connector (Male 2-wire leads) – The Fiero Store
1 – Mom-On-Off- Mom-On 30A DPDT Toggle Switch – Radio Shack
1 – 20A Circuit breaker - AutoZone
The power is pulled from the Batt (Battery) Always hot power block that I have installed in the car. This was easy since I have relocated the battery to the front of the vehicle. Power is then fed to the headlight motor circuit via a 20A Circuit breaker.
I installed the control switch, a DPDT 30A Mom-On – Off – Mom-On switch in the position that was originally intended for the “Rear Window Defrost”. My ’86 GT is not equipped with “Read Window Defrost” making the switch installation a breeze.
I ran the feed wires for both headlight control motors and installed newly purchased “The Fiero Store” 87-88 Headlight Motor connectors. In the photo you will see that I left the OEM connector (Gray) intact. This is for future use in the event I locate a functional Headlight Motor Control Module.
The schematic for the project:
This was my solution to not having functional headlight motors. It maynot be feasible for your particular application but worked for me.
Cajun
Report this Post01-29-2014 03:05 PM Click Here to See the Profile for CajunSend a Private Message to CajunEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry guys about the double post. My computer hung up and for ever the reason did a second post.
Report this Post01-30-2014 02:42 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Module(s) maybe ok but your motor(s), HL switch, or wiring have problems. A binding door and/or bucket too.
See my Cave, Gen 2 HL Motor
Sorry but W/o the module, you will likely break motor's bottom end. Strip output shaft, strip gears, shattered dowels.
Module is much better and faster to read motor load and shutdown anywhere in opening or closing if door or bucket get stuck.
Please add thumb to img tag. Click PFF Code is ON on post/edit page.
[This message has been edited by theogre (edited 01-30-2014).]
Cajun
Report this Post01-30-2014 07:29 AM Click Here to See the Profile for CajunSend a Private Message to CajunEdit/Delete MessageReply w/QuoteDirect Link to This Post
Believe me the modules were inoperative. Not 100% but enough to render not operational. I have the proper test equipment to test the modules. In fact, the modules were tested on a bench set-up prior to being installed in the vehicle.
The trick to not stripping the motor gears is to stop the movement of the headlight doors when you think they have bottomed. This method works for me but may not be your cup of tea.
Dodgerunner
Total ratings: 323
Report this Post01-30-2014 08:34 AM Click Here to See the Profile for DodgerunnerClick Here to visit Dodgerunner's HomePageSend a Private Message to DodgerunnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
This post might help. Read my post about 7/8th down.
https://www.fiero.nl/forum/A...130314-2-113825.html
Cajun
Report this Post01-31-2014 07:28 AM Click Here to See the Profile for CajunSend a Private Message to CajunEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm surprised that no on questioned the two relay blocks that I have installed in the front truck area!
Report this Post02-01-2014 05:32 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
How did you figure 20A breaker?
Cajun
Report this Post02-05-2014 12:30 PM Click Here to See the Profile for CajunSend a Private Message to CajunEdit/Delete MessageReply w/QuoteDirect Link to This Post
An educated guess, more or less.
I.e. Most of the circuits that contain any type of motor is more times than not protected by a 20A fuse. I bench tested my headlight door motors and they pulled between 5 and 7 amps. Keep in mind the doors were not attached during the bench test. Further, fusible link of wire size .35mm has a rating of about 10 amps.
I initially used a 15A breaker but it would trip every so often. I then installed a 20A and have not had any issues since.
Report this Post02-05-2014 02:38 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
"between 5 and 7 amps." total or each motor?
Total maybe ok or not.
Each then System/Motors still may have problems... Module cutting out is saying I see problems and shut down power to motor(s) to save the system.
Gen2 system is better but small things can get module to shut off power. I've seen motor going very tight when doors close and Module refuse to open after until you turn the knob 1 turn to release tension. Motors needed clean and lube. Other examples: miss-adjusted screw on bottom of motor, binding door and/or bucket parts.
A Motor sees high current at stall etc and tripping 15A breaker is not good for the long run. A breaker rated at 15A will trip at ~18A or more.
For comparison:
Contacts for Relay inside module is 1.5 A @ 24vdc for Inductive(motor) load, 3A max.
Google: omron my4-02 12vdc
Note some pages use update datasheet and change to 30vdc etc.
If you don't want them, I'm looking for iffy/dead modules and motors for the Gen2 cave article. Donations are welcome.
LornesGT
Report this Post02-05-2014 11:14 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I will bite. What are they for?
mitchjl22
Report this Post02-06-2014 01:42 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm interested in your climate control! Got any links for that?
