  Help with 3800sc swap. parts list
Help with 3800sc swap. parts list by crashmydaytona
Started on: 01-28-2014 03:08 PM
Replies: 2 (323 views)
Last post by: Lou6t4gto on 01-29-2014 06:19 PM
crashmydaytona
Report this Post01-28-2014 03:08 PM Click Here to See the Profile for crashmydaytonaSend a Private Message to crashmydaytonaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I already have the big stuff engine, tranny, mounting brackets, wire harness, shifter bracket or at least its on its way, fuel lines, front mount battery kit
Things I know I need but don't know what brand or type to get
Fuel pump
sending unit
thermostat housing with nipple for coolant connection. ( might build this)
axles (might build these as well but probably buy them)
Thats really all I can think of but I am sure there is more and I would like to get stuff bought so if you can help me with what other parts I need or what part # or brand I will need would be great. Thanks
hercimer01
Report this Post01-28-2014 07:42 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is what I did.
Originally posted by hercimer01:
Here goes, I will use this text box to update the price tag.
1986 Fiero GT 49k miles with a blown motor
$900.00__
1998 GTP 130K miles whole car
$500.00__
Odds and ends
$119.00__Title
$35.00__Registration, Antique vehicle, 4 years worth
$14.99__Center console
$22.49__High temp paint
$9.98__Undercoat
$201.46__TL
Air intake;
$24.99__8132 Spectra air filter
$5.77__Drain pipe
$1.15__3" PVC coupling
$3.00__Clamps
$34.91__TL
Exhaust;
$119.89__Flotech afterburner w/shipping
$140.00__ Exhaust pipes
$6.99__Exhaust flange gasket, 1
$5.88__Tail pipe hanger universal, 2
$5.99__ Aluminum engine enamel,1
$278.75__TL
Brakes, Grand Am upgrade, rear only
$47.98__Brake hoses
$10.49__Brake pads
$45.98__Calipers
$39.98__Rotors
$20.00__Brake lines
$164.43__TL
Transmission
$7.49__Pax 560 brake line
$20.23__Trans cooler hose
$13.99__ Trans Filter
$29.98__Tans fluid, 2 Gal
$7.49__Gear selector
$10.99__Gear shift select cable
$12.00__Hose menders
$102.17__TL
Axles
$14.34__Half shaft
$9.99__ Grease
$24.43__TL
Suspension
$45.00__POR15
$120.00__Sandblast cradle
$51.98__FA1146 Rear lower ball joints
$25.17__7304 Control arm bushings Prothane
$48.57__7502 Cradle bushings Prothane
$290.72__TL
Engine
$350.00__FieroX motor mounts
$21.99__820K6 serpentine belt
$14.99__665K6 serpentine belt
$21.99__ 5W-30 Oil, 4 qts
$3.99__Oil filter
$1.99__ VS50465R Valve cover gaskets
$11.97__Fuel injector Orings
$4.99__61024 TBI gasket
$15.99__TU179 temp switch
$16.99__231086 Idler pulley
$50.79__MS98014T LIM gaskets
$1.99__MS95744 UIM gasket
$5.99__Black silicone
$4.44__Plug wires
$45.79__89367 Belt tensioner.
$8.99__15849 Thermostat
$4.99__Oil pressure sensor
$26.94__APP606 spark plugs
$614.48__TL
Electrical
$00.00__ Wire Harness self fabricated
$75.00__Pre programmed PCM from nosrac
$91.15__Battery
$4.99__Battery tray, stock
$2.98__ Electrical tape, 2 rolls
$174.12__TL
Cooling
$24.00__Coolant tee
$00.00__Filler tee
$49.99__Automatic radiator
$20.99__E72003 Radiator hose
$2.38__Heater hose
$10.98__Hose clamps
$9.99__Over flow tank
$118.33__TL
Fuel
$21.99__PT2352 ACDelco fuel pump pigtail
$18.76__Fuel hose
$79.99__Fuel pump (Airtex equivalent to EP376)
$14.99__Fuel filter
$135.73__TL
$3403.80__TTL
$1400.00__Minus cars
$2003.80__With out the 2 cars for just the various stuffs.
plus 7.25% sales tax
I think that is pretty much it. I will up date it as I think of more.
Not including paint or windows.
88 Coupe under construction
Lou6t4gto
Report this Post01-29-2014 06:19 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
From the thermostat housing, I used an aluminum "inline" pipe with a radiator cap on it ( available on ebay) you just put it "inline" with the upper radiator hose, and you have a convenient FILL point.
