  Possible Koni alternative for 88 fronts
Possible Koni alternative for 88 fronts by KissMySSFiero
Started on: 01-27-2014 10:19 AM
Replies: 6 (690 views)
Last post by: qwikgta on 01-29-2014 08:22 PM
KissMySSFiero
Total ratings: 111
Report this Post01-27-2014 10:19 AM Click Here to See the Profile for KissMySSFieroSend a Private Message to KissMySSFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since Koni doesn't make front shocks for the 88's anymore. I've been searching for an alternative.
Thru cross referencing what works on an 88 to where those work on other cars I found this.
There's several other applications that might work that have different Koni part numbers.
I'll have to dig more into this but thought I'd open a discussion for anyone wanting Koni's on there 88's
http://www.summitracing.com...n-80401020/overview/
SSFiero@Aol.com
Total ratings: 237
Report this Post01-27-2014 03:03 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
The big thing that makes the '88 shocks difficult to adapt is the very short collapsed length... if you can get an interchangeable body, then the Koni custom shop can install whatever valving you want into it.
eunospeed
Report this Post01-28-2014 09:16 AM Click Here to See the Profile for eunospeedSend a Private Message to eunospeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm looking for a solution too, I would really like something better than Monroe struts. I'll be watching this thread....
Fierobsessed
Total ratings: 147
Report this Post01-28-2014 09:46 AM Click Here to See the Profile for FierobsessedSend a Private Message to FierobsessedEdit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC, aren't 90's - 00's S10/blazer shocks similar to 88 fronts? I don't have a clue about the length issue, but I just thought I'd throw that out there.
KissMySSFiero
Total ratings: 111
Report this Post01-28-2014 09:38 PM Click Here to See the Profile for KissMySSFieroSend a Private Message to KissMySSFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is exactly my concern. I'll investigate soon to see if I can find a shock that fits. I don't think this is a deal killer. On the 88's you can raise the top shock mount if needed.
My other concern is that these are designed for older muscle cars. I'm not a shock engineer, but I imagine there are differences in the valving.
SSFiero@Aol.com
Total ratings: 260
Report this Post01-28-2014 10:06 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The mid 70's D100 trucks use a front shock that is almost the exact same length as the 88 front and uses the same mounting method. For some odd reason it still being manufactured and 3 versions of the shock are actually in stock items at my local Autozone. There are several variations and they even come in larger piston sizes.
Just one of those things I stumbled across one day looking for something else.
fieroguruperformance.com
qwikgta
Total ratings: 84
Report this Post01-29-2014 08:22 PM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
would love a fix for this. I bought the AMS tubular upper/lower control arm kit w/ QA1 shocks. I almost bought the WCF lower A arm kit that puts a hole in the middle and you install a drop in fitting, but I was not sure if the whole thing was a good idea.
Keep up the search.
Rob
