  Quad 4 Fiero running poorly
Quad 4 Fiero running poorly by Madess
Started on: 01-27-2014 09:50 AM
Replies: 18 (417 views)
Last post by: Joseph Upson on 02-02-2014 01:46 PM
Madess
Report this Post01-27-2014 09:50 AM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did a tune up, and there are no fuel issues, so it must be a sensor or something. I have a 1990 HO quad 4 in my car, and I need to know software and hardware wise what is required to connect to the cars computer and find out what is happening.
Thanks for any help
conan469
Report this Post01-27-2014 04:12 PM Click Here to See the Profile for conan469Click Here to visit conan469's HomePageSend a Private Message to conan469Edit/Delete MessageReply w/QuoteDirect Link to This Post
what symptoms are you having?
and tune up? just plugs? or coil towers too?
Madess
Report this Post01-27-2014 06:43 PM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
At about 3000 rpm's it seems like it is missing really badly. I have also replaced everything in the ignition system. Fuel pressure is good. I also replaced the crank sensor.
Madess
Report this Post01-30-2014 07:25 AM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any other help?
conan469
Report this Post01-30-2014 07:52 AM Click Here to See the Profile for conan469Click Here to visit conan469's HomePageSend a Private Message to conan469Edit/Delete MessageReply w/QuoteDirect Link to This Post
i got nothing, sorry.
without scanning for codes or seeing live data to know what the ecm is seeing it makes diagnostics a guessing game.
[This message has been edited by conan469 (edited 01-30-2014).]
craigsfiero2007
Total ratings: 71
Report this Post01-30-2014 08:08 AM Click Here to See the Profile for craigsfiero2007Send a Private Message to craigsfiero2007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you check for vacuum leaks? When you replaced the ignition coil, did you replace the coil housing (battleship) and the boots?
Joseph Upson
Total ratings: 88
Report this Post01-30-2014 08:33 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did the problem start before, or after the tune up? If after of course you need to go over everything you did and possibly need to swap old parts back in place one part or group at a time.
If it was pre existing, is this a manual or automatic car? That code if I'm not mistaken has a rev limit linked to the park neutral switch which activates at about 3000 rpm. If a wire is loose or the switch has failed that maybe what the problem is. If the car had the problem when you purchased it the chip may have the wrong rpm limit set in it. Tunerpro which many DIY programmers use has a glitch that actually has the opposite effect when you raise the rpm limit in the code.
You may need to search out the signal wire to make sure it is connected properly to the P/N switch.
Madess
Report this Post01-30-2014 11:33 AM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
The car is a manual, I replaced everything on the ignition system including the housing, because one day it started running very poorly.
Joseph Upson
Total ratings: 88
Report this Post01-30-2014 12:28 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does the motor have a timing belt or chain and have you checked the fuel pressure yet? A weak and failing fuel pump can get you going and start to fall short on fuel supply as demand increases. If you do not have a fuel pressure tester a quick way to test for a fuel problem is if the engine breaks up also as you raise the rpm while in neutral. If so you can try to spray a little starter fluid into the throttle body at the break up point and note the effect. If it is starving of fuel the problem will clear immediately momentarily. Get help doing this as starter fluid acts like nitro some times so you only want to spray a quick burst.
Madess
Report this Post01-30-2014 02:37 PM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
Madess
Report this Post01-30-2014 03:08 PM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
Madess
Member since Feb 2004
cmechmann
Report this Post01-30-2014 09:40 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does your check engine/SES light work? Is it on or come on when it breaks up? If so search for pulling codes on ALDL connector.
Did the engine start to sound like marbles rolling inside the bottom of a bucket? You chain tensioner could be going causing your timing chain to get sloppy.
Quad 4s are good for that.
Breaking down on hIgher RPMs. Do you keep an extra ignition module around?
And since this started all the sudden and this is a swap, start checking for loose connections.
[This message has been edited by cmechmann (edited 01-30-2014).]
Madess
Report this Post01-31-2014 01:07 PM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
SES does work and it isn't setting any codes. I have checked fuel pressure at idle and it is good. I will check fuel pressure at higher rpm's.
It looks like for tunercat, I need the program for 01228707, that is the service number on my ecm.
Sorry for the multiple posts, my computer was having issues.
Joseph Upson
Total ratings: 88
Report this Post01-31-2014 06:23 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
A bad MAP sensor will do this. I had one nearly cause me to give up on my 3900 swap because it never set a code. I just happened to notice in the datalog that the signal from the MAP sensor was fixed and constant.
If it sets at a part throttle value you will not likely notice a problem until the engine load exceeds that point where it will then start to lean out the engine, for example, engine load fixed at 40% and throttle input is calling for 60%. The engine will fall over everytime as soon as that point is exceeded.
Madess
Report this Post02-01-2014 04:29 PM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the MAP as well, no luck.
Joseph Upson
Total ratings: 88
Report this Post02-02-2014 07:22 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Data link is the only thing left although you should still check into the wiring for the two stage rev limit as well. Check with autozone, they may have a scanner that will allow you to link up with OBD1. Mine does although I use TunerproRT instead. Tunerpro does at least the 1990 Quad, and Moates.net can supply you with the data link cable for I believe about $50. I have Tunercat also but Tunerpro in my opinion is far better as it allows you to see where you are on a particular table while the motor is running plus emulate among other things.
You'll need to record the sensors at the trouble spot and go back and look at what they are doing in the log.
dematrix86gt
Report this Post02-02-2014 12:32 PM Click Here to See the Profile for dematrix86gtSend a Private Message to dematrix86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a 96 z24 with the 2.4 twin cam in it and the coil tower gave me fits. kept buying the master pro brand and at WOT my coils would arc thru them. Finally gave up and went to Chev dealer and got a Original tower and that cleared my problem. with the way the top plate covers everything kinda hard to look at things without a bore scope. it can get up in there so you can see.
Madess
Report this Post02-02-2014 12:59 PM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have Tunerpro, and the Moates cable, and I just ordered $a8 from the tunerpro folks. I am travelling for work for the next days, but Wednesday I should be able to pull the sensors and get some more information.
Thanks for all the help.
Joseph Upson
Total ratings: 88
Report this Post02-02-2014 01:46 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
All coil packs are not created equal, not even OE from overseas so be careful when bidding on what looks like a great price on OE old stock from ebay. I purchased a set that broke up on the dyno having been installed the day before. On examination I found little cracks in the bottom of the casing on all 3. Some parts are dealer only must, or good used OE and this is one of them.
