  Is this the correct way to get OBD-I codes from a Fiero?
Is this the correct way to get OBD-I codes from a Fiero? by hdryder
Started on: 01-26-2014 08:07 PM
Replies: 3 (129 views)
Last post by: theogre on 01-26-2014 09:27 PM
hdryder
Report this Post01-26-2014 08:07 PM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
1. Ground terminals A and B (see diagram below at first link below) with the ignition "ON" and engine not running. The system will enter the diagnostic mode. In this mode, the computer will display a Code 12, three consecutive times, by flashing the "CHECK ENGINE", "SERVICE ENGINE SOON" or "MALFUNCTION INDICATOR LAMP" or light. A Code 12 consists of one flash, a short pause, then two flashes in rapid succession.
2. After Code 12 is displayed, any stored trouble codes will be displayed by flashing the "CHECK ENGINE", "SERVICE ENGINE SOON" or "MALFUNCTION INDICATOR LAMP" light. All codes are displayed 3 times each then a code 12 will repeat. In the diagnostic mode, the computer will also energize all computer controlled relays and solenoids.
http://www.obd-codes.com/fa...t-obd-codes-free.php
GM 2 Digit Trouble Codes
http://www.obd-codes.com/tr...gm-2-digit-codes.php
Report this Post01-26-2014 08:24 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post01-26-2014 08:55 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would say that's almost correct for the Fiero. You can use a paper clip shaped into a U to ground A and B. But, When inserting or removing the clip, the ignition should be OFF. Once inserted, turn the ignition ON but don't start and it will go through the described sequence of flashes. Once the loop goes back to 1 Flash-2 Flash, turn the ignition OFF and remove the paper clip.
The diagram in your link shows the diagnostic port installed upside down to what it is in the Fiero. The A and B terminals are on the lower level, passenger side of the ALDL.
[This message has been edited by fierofool (edited 01-26-2014).]
Report this Post01-26-2014 09:27 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
See my Cave, ALDL/ALCL
