  4spd Clutch Arm Junkyard Cross Reference
4spd Clutch Arm Junkyard Cross Reference by mitchjl22
Started on: 01-25-2014 01:30 AM
Replies: 4 (357 views)
Last post by: Gall757 on 01-25-2014 12:46 PM
mitchjl22
Report this Post01-25-2014 01:30 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello, a quick search didn't yield any results, but I'm looking for a clutch arm for the 4spd my dad has. He flew into town this weekend only and we found that his clutch arm was causing the clutch problems. My 5-speed Getrag clutch arm looks really similar. I understand that the early 4spd cars had a stamped clutch arm and was later replaced with a one piece cast one.
If I go to a junkyard tomorrow, will I be able to find one off of another car?
Part number is 10039912 as pictured.
Thanks,
-Mitch
weaselbeak
Total ratings: 76
Report this Post01-25-2014 02:55 AM Click Here to See the Profile for weaselbeakSend a Private Message to weaselbeakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a brand new one, not that stamped POS, that could be had very reasonable.
tesmith66
Total ratings: 135
Report this Post01-25-2014 07:25 AM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
You can weld the stamped one up enough to get you by until the cast one you buy from weaselbeak comes in. I doubt you'll find one in the yard.
1986 SE Aero coupe.
mitchjl22
Report this Post01-25-2014 10:53 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do I have to replace the clutch arm and the clutch fork? Or can I do what we're talking about and repair mine until I buy one.
Report this Post01-25-2014 12:46 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You can replace just the arm. The cast one is the way to go.
