  EGR Pipe Replacement Hints for 2.8L?
EGR Pipe Replacement Hints for 2.8L? by Ray_and_kevin
Started on: 01-21-2014 03:52 PM
Replies: 11 (1340 views)
Last post by: fierofool on 09-28-2023 07:08 PM
Ray_and_kevin
Report this Post01-21-2014 03:52 PM Click Here to See the Profile for Ray_and_kevinSend a Private Message to Ray_and_kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Time to take the old one off and put the new one on. Looks like 2 ways to do it. First is to remove the distributor so you can get to the bolts on the bottom of the intake manifold. second is to remove the throttle body so you can reach the bolts. Any suggestions? Is there yet another way?
Thanks in advance.
Ray
Spoon
Total ratings: 61
Report this Post01-21-2014 06:38 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Remove the distributer cap and 3 plug wires so you can swing the cap out of the way. Take your "not so good" 10 mm box wrench and put it in a vise. Start bending it to accommodate the angle you need to reach the bolts under the intake. Also take a wash cloth and stuff it down into the pockets where the bolts may fall and be gone forever.
I've done this enough times I should get a patent for the bent wrench.
Edit to mention the 10mm may be a 9mm. Check before bending...
Spoon
[This message has been edited by Spoon (edited 01-21-2014).]
Ray_and_kevin
Report this Post01-21-2014 08:57 PM Click Here to See the Profile for Ray_and_kevinSend a Private Message to Ray_and_kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spoon:
I never would have thought of that. Excellent solution. Only problem is that I don't have a 10mm to spare (ought to be since the EGR end is 10mm). Only have one 10 mm wrench :-( I should be able to get a "bent" 10 mm at Autozone or some other tool place, though.
Thanks
Ray
georgie
Report this Post01-21-2014 10:40 PM Click Here to See the Profile for georgieSend a Private Message to georgieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just did a tube change an it was not hard to do if you remove the dis cap as spoon said, also take a rag an put it under the tube bolt's so if thay fall (an thay will most likely) you can slide the rag out to grab them. I also would put the left bolt back in first under the intake it's the hardest one to do. Put some heavy grease on it. It will help hold it in place so you can move you hand to spin it to git it started. Have a cold beer handy an take your time an just stay cool, an you'll be done before you know it. Good luck.
Ray_and_kevin
Report this Post01-21-2014 11:14 PM Click Here to See the Profile for Ray_and_kevinSend a Private Message to Ray_and_kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
This group never disappoints. Thanks for the grease and beer suggestions. Both important!!
georgie
Report this Post01-21-2014 11:41 PM Click Here to See the Profile for georgieSend a Private Message to georgieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ha, remember to disconect the battery so you don't fry somthing!!!! like your self....
mitchjl22
Report this Post01-22-2014 09:14 PM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
I took off the upper intake, 2 intake gaskets and a TB gasket later and I was in business... maybe an hour tops...
Ray_and_kevin
Report this Post01-22-2014 09:19 PM Click Here to See the Profile for Ray_and_kevinSend a Private Message to Ray_and_kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, I have a new EGR tube installed. Thanks for the ideas. I ended up buying a ratcheting box end at Sears that lets you set the angle. It was $19.99 but worth the cost. The right hand bolt was the hardest to get out and needed a regular box end to break it loose first. Need to ask Santa ( or Mrs. Claus) to get me a whole set of those wrenches this Christmas.
I cut the cover off the corrugated tube and did not see any cracks or other holes, so I have a new pipe but likely did not fix the problem. So the guess is either the IAC sticking or the EGR is actually open.
Have to wait for tomorrow to replace the rotor that broke when I tried to remove it. Then I can diagnose more. Thing was rusted to the shaft!!! Never saw that much rust inside a distributor. This rotor and cap had to be on there for a decade or more.
IXSLR8
Report this Post01-23-2014 12:58 AM Click Here to See the Profile for IXSLR8Send a Private Message to IXSLR8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Or your EGR controller.
It's always a good idea to take your upper intake off at least once, like previously stated, because you can look over all the plastic vacuum tubes and fix them if any one is plugged or cracked. Can't really observe them if the intake is on as its in the way.
Total ratings: 290
Report this Post01-23-2014 05:47 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sand the rust off of the shaft so you don't split your new rotor. It will also help when you try to get it off of the shaft in 2024
bergertime
Report this Post09-28-2023 06:10 PM Click Here to See the Profile for bergertimeSend a Private Message to bergertimeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hopefully you sanded that rust off as it's almost time.
Report this Post09-28-2023 07:08 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Smear a little anti-seize on the top of the shaft before installing the new rotor button. All the rust is created by the ozone generated by the spark coming off the rotor button tip.
