  Weird Noise!!
Weird Noise!! by 4thfiero
Started on: 01-20-2014 01:13 PM
Replies: 9 (269 views)
Last post by: dematrix86gt on 02-08-2014 11:29 AM
4thfiero
Report this Post01-20-2014 01:13 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey everyone, I have finally got my vehicle up to "good" status, the only complaints i have left are these 2 weird noises im hoping someone might be able to help with...
1) When accelerating from a stop there is a creaking noise coming from the rear of the car somewhere...like a creaky door opening, i dont hear it when im going like 20kph or above...but at very slow 1st gear speeds, pumping the gas and urking the car forward, any ideas?
2) I think i know what this is but i'll ask anyways, when accelerating while in 4th an 5th (noise gets worse with harder accelerating in a higher gear) i hear this sound that sounds like....wind mixed with a soft rattle or a gurgling...the noise was about 80% fixed yesterday when i changed the gaskets around my erg dome...maybe i have a cracked tube and that's the noise?
Report this Post01-20-2014 01:54 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You always wonder about motor mounts with that sort of description, although I must admit I am not familiar with 'urking'.
4thfiero
Report this Post01-20-2014 02:00 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was thinking that, or maybe sub frame bolts???
Report this Post01-20-2014 02:22 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you have a helper, they should see the engine move as you are urking the car....(standing from a safe place). You also may be able to put the car in gear and rock it back and forth (engine off) to see engine movement. Any twisting motion would be a bad engine/trans mount.
4thfiero
Report this Post01-20-2014 02:34 PM Click Here to See the Profile for 4thfieroSend a Private Message to 4thfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
You could probably see that on a dyno too right? There's a shop i might take the car too that can dyno it.
Report this Post01-21-2014 09:03 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Strut noise maybe?
What is an "erg dome"?
carbon
Total ratings: 130
Report this Post01-21-2014 12:30 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 2.5:
Strut noise maybe?
EGR valve? Kinda looks like a dome... if Aztecs made domes.
Report this Post01-21-2014 01:54 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
It does!
Earnie_B
Report this Post02-07-2014 07:47 PM Click Here to See the Profile for Earnie_BSend a Private Message to Earnie_BEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine was making the same sound usually in first gear from a stop, sometimes after shifting to second. I just got the car back from the shop today after having the engine and transmission mounts replaced. Noise is gone. Total parts cost less than $50.00 and $60.00 labor. My mechanic said the mounts weren't deformed but were probably original and just worn out.
dematrix86gt
Report this Post02-08-2014 11:29 AM Click Here to See the Profile for dematrix86gtSend a Private Message to dematrix86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Had that same prob and mine turned out to be that little shock looking thing on the cradle on the firewall side. I sprayed the inside full of silicone spray and the noise went away so i picked up another one and replaced it. worth a shot to spray yours and see if it goes away.
