  Duke high idle after cleaning throttle body
Duke high idle after cleaning throttle body by Csjag
Started on: 01-19-2014 03:45 PM
Replies: 3 (191 views)
Last post by: Blacktree on 01-19-2014 06:07 PM
Csjag
Report this Post01-19-2014 03:45 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I took off the throttle body on my 85 duke and cleaned the passages out and the gunk buildup. Got it back on and the car runs great but now the idle is high, my tach isn't accurate so I don't know exactly how high but its about twice as high as it idled before. Car will go 15 mph in second with my foot off the gas. I don't see any vacuum hoses disconnected or leaking. Anyone have any ideas? Thanks
Report this Post01-19-2014 05:29 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
A bad seal on the intake manifold? Vacuum lines switched? EGR valve loose? The engine is getting more air somehow.
Csjag
Report this Post01-19-2014 05:46 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess I didn't wait long enough for the computer to adjust, just restarted it and it idles down now like before. It does have an exhaust sputter every few seconds, what causes that an exhaust leak?
Blacktree
Total ratings: 350
Report this Post01-19-2014 06:07 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The computer got used to opening the idle air valve a little more, to compensate for the reduced airflow. When you cleaned out the crud, you restored the airflow. So the ECM had to re-adjust.
That said, it's a good idea to reset the ECM when you do something like that to wipe the slate clean, so to speak. You may want to do that anyway, even though it seems to have re-adjusted.
As for the sporadic sputter, it's hard to tell without more info.
