  3800 Coolant Drain on Engine?
3800 Coolant Drain on Engine? by don297
Started on: 01-18-2014 04:57 PM
Replies: 2 (255 views)
Last post by: don297 on 01-19-2014 12:47 PM
don297
Report this Post01-18-2014 04:57 PM Click Here to See the Profile for don297Send a Private Message to don297Edit/Delete MessageReply w/QuoteDirect Link to This Post
So theres a bolt next to the crank pulley, on the right, when removed coolant drains from it. Problem is that when i took my engine apart, i didn't label which bolt goes there. the only one I have left that will fit is identical to the engine mount bolts on the left side of the engine. (It has some kind of washer on it) Is this the proper bolt to use? If so, anyone know torque specs or if i should use threadlocker on it?
sco77
Report this Post01-18-2014 05:51 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
My engine has no original bolts whatso ever, I just matched up threads and measured and ordered online or hardware store... Use whatever bolt matches and use thread SEALANT on bolts that go into coolant passages.
86 Fiero GT 4spd - L67 swap: VS cam, GenV
98 GTP - Some mods
don297
Report this Post01-19-2014 12:47 PM Click Here to See the Profile for don297Send a Private Message to don297Edit/Delete MessageReply w/QuoteDirect Link to This Post
Would threadlocker blue work as a sealant?
