  Need help?? Engine wont run possible timing??
Need help?? Engine wont run possible timing?? by wickedjester
Started on: 01-18-2014 12:19 PM
Replies: 14 (161 views)
Last post by: wickedjester on 01-19-2014 03:36 PM
wickedjester
Report this Post01-18-2014 12:19 PM Click Here to See the Profile for wickedjesterSend a Private Message to wickedjesterEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have an 86 gt 2.8. Was running fine then just wouldnt start, tested it and found it had no spark, got icm tested and it was good so i replaced the coil. fixed the spark problem. now it tries to hit but sounds like it detonating. if i hold the throttle down it wil run very rough for a couple of seconds then die. It blows black smoke the whole time and by rough i mean backfiring violently the whole time. really sounds like the timing is way out. Was wondering how prone these things are to the chain slipping or loosing a tooth on the gear. Or any other ideas would be appreciated.
Report this Post01-18-2014 12:27 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's more likely that you moved something when you were playing with the ICM. Check connectors, make sure the pickup coil wire is not pinched under the distributor cap. Make sure the distributor did not rotate a little. Also, the ICM still might not be right....those tests are not perfect.
wickedjester
Report this Post01-18-2014 01:10 PM Click Here to See the Profile for wickedjesterSend a Private Message to wickedjesterEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok went ahead and changed icm, checked connectors they r good, no pinched wires, and cant turn the distributor, same result
Report this Post01-18-2014 01:17 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The chains have been pretty reliable on the 2.8. How many miles are on your engine?
wickedjester
Report this Post01-18-2014 01:23 PM Click Here to See the Profile for wickedjesterSend a Private Message to wickedjesterEdit/Delete MessageReply w/QuoteDirect Link to This Post
147 and change
Report this Post01-18-2014 01:48 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
grkboy707
Report this Post01-18-2014 01:52 PM Click Here to See the Profile for grkboy707Send a Private Message to grkboy707Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you check for compression?
Csjag
Report this Post01-18-2014 02:50 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fuel pump working?
wickedjester
Report this Post01-18-2014 02:52 PM Click Here to See the Profile for wickedjesterSend a Private Message to wickedjesterEdit/Delete MessageReply w/QuoteDirect Link to This Post
compression is ok on it i will pull a plug find tdc and see where the distributor pionts
BrittB
Report this Post01-18-2014 09:04 PM Click Here to See the Profile for BrittBSend a Private Message to BrittBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just went back through my entire ignition system and I found crimped wires on the induction coil. Installed my new spare and then I had a good spark. This was on a brand new distributor too!
wickedjester
Report this Post01-19-2014 11:39 AM Click Here to See the Profile for wickedjesterSend a Private Message to wickedjesterEdit/Delete MessageReply w/QuoteDirect Link to This Post
ok so i checked tdc on #1 and the ditributor points right at it so no timing chain slip. Checked spark and its getting good spark. its getting plenty of fuel as well. not sure where to try next
Report this Post01-19-2014 01:57 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Look at the vacuum lines around the MAP. If one has come off, the car can sound like that.
wickedjester
Report this Post01-19-2014 02:49 PM Click Here to See the Profile for wickedjesterSend a Private Message to wickedjesterEdit/Delete MessageReply w/QuoteDirect Link to This Post
if it was a vacuum line wouldnt it still start?
Report this Post01-19-2014 02:58 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
What do the plugs look like? Are they all carboned or sooted up? Proper gap?
wickedjester
Report this Post01-19-2014 03:36 PM Click Here to See the Profile for wickedjesterSend a Private Message to wickedjesterEdit/Delete MessageReply w/QuoteDirect Link to This Post
plugs r only a couple weeks old and look good, to update a little when i crank on it, when it hits the engine kicks back hard enough to disengage the starter from the flywheel
