I figured this might be helpful for me, so it might be helpful for others too, parameter addresses for the short* bin osid 12586835 all addresses are according to tiny tuners database. I think some might be wrong though, still looking into it.
1c970-ect temp vs votage
6f1d8-ignore flash checksum
6f1d9-disable flash security
6f1da-module programmed
6f1dc-engine type
6f1dd-crank resolution
6f1de-supercharger present
6f1e8-a/c RPM disable
6f1f4-a/c on startup delay
6f208-a/c min air temp
6f20a-a/c disable/re-enable ECT
6f20e-a/c disable/re-enable tps
6f212-a/c disable timer
6f22a-a/c disable/re-enable ignition voltage
6f234-MAF airflow table
6f2d6-MAF max positive airflow change
6f2fc-MAF negative airflow change
6f398-transient airmass calc mode
6f39a-max cylinder air mass
6f3a0-transient airmass calce enable positive tps delta
6f3a2-transient airmass calc enable negative tps delta
6f3aa-default mass airflow (GM/sec) vs TPS vs RPM
6f674-MAF failure airmass calc mode
6f68a-speed density maf compensation vs ect
6f69e-speed density maf compensation vs baro
6f736-volumetric efficiency
6f934-ve correction vs tps vs egr state
6f94c-speed density maf compensation vs IAT
6fae0-air pump system present
6faf6-air pump enable startup coolant temp
6fb2c-alternator startup delay vs ECT
6fb40-alternator RPM cutout
6fbea-default baro
6fbec-always use default baro
6fbf0-SC baro lookup
6fc32-NA baro lookup vs tps vs rpm
6fe4e-o2 sensor config for pid 13
6fe50-boost delay-boost timer base
6fe66-boost delay-timer adder tcs on
6feaa-boost delay-timer adder tcs off
6fefe-CCP enable coolant temp
70060-ect ok enable ert
70062-ect ok enable ect
70064-ect ok disable ect
70066-ect ok enable ect dtc set
70068-ect ok disable ect dtc set
7006a-ect temp vs ert
702d6-knock sensor diagnostic min ect
702d8-knock sensor diagnostic min engine load
702da-knock sensor diagnostic rpm thresholds
702e8-knock sensor diagnostic min ert
702ec-knock sensor circuit diagnostic min fails per sample to set DTC
702ee-knock sensor circuit diagnostic test sample size
702f0-knock sensor diagnostic min fails per sample to set DTC
702f2-knock sensor diagnostic test sample size
702f4-knock sensor diagnostic max KR
702f6-knock sensor diagnostic min tps
702f8-knock sensor diagnostic min ign volts
714e4-flash checksum
71502-CAT diagnostic tests per trip
71503-CAT diagnostic tests count to pass
71504-CAT diagnostic tests count to fail
7150a-idle diagonostic min tests to set dtc
71512-max idle rpm variance vs ect
71596-crank and cam sensor circuit diaognosic min ERT
71598-p0341 min fails per sample to set dtc
7159a-p0341 test sample size
7159c-p0336 min fails per sample to set dtc
7159e-p0336 test sample size
715a0-p1374 min fails per sample to set dtc
715a2-p1374 test sample size
71638-max MAF frequency
7163e-min maf frequency
71644-maximum delta airflow
7165a-p0106 max map volts vs tps vs rpm
716f4-p0106 man map volts vs tps vs rpm
7178e-p0108 and p1106 min fails per test sample to set dtc
71790-p0108 and p1106 test sample size
71792-p1107 min fails per test sample to set dtc.
71794-p1107 test sample size
71796-p0106 number of times out of range to set p0106
7179a-p0108 min fails tper test sample to set DTC
7179c-p0108 rpm threshold
7179e-p0108 test sample size
717a0-p0107 min fails per test sample to set DTC
717a2-p0107 RPM threshold
717a4-P0107 test sample size
717a6-p0108 min map volts
717a8-P0107 max map volts
717aa-p0108 max tps above rpm threshold
717ac-p0107 min tps above rpm threshold
717ae-p0108 max tps below rpm threshold
717b0-p0107 max tps below RPM threshold
717b6-p1112 min mph
717b8-p0113 min ect
717ba-p0113 max airmass
717bc-p0113 max mpH
717be-p0113 min ert
717c2-p1112 min ert
717c7-p0112 min raw IAT count
717c8-P0113 max raw IAT count
717ca-p1111 and p1112 test sample size.
717cc-P0113 min fails per test sample to set dtc
717ce-p0112 min fails per test sample to set DTC
717d0-p1111 min fails per test sample to set dtc
717d2-p1112 min fails per test sample to set dtc
717d4-p0112 and p0113 test sample size
717d6-p0030 fail time
717d8-p0300 IGNV thresholds
717dc-p0230 fail time
717de-p0230 ignv thresholds
717e2-p0403 fail time
717e4-p0403 ignv thresholds
717e8-p0654 fail time
717ea-p0654 ignv thresholds
717ee-p1689 fail time
717f0-p1689 ign v thresholds
71860-p1121 min fails per test sample to set dtc
71862-p1121 test sample size
71864-p1122 min fails per test sample to set dtc
71866-p1122 test sample size
71868-p0121 min ect
7186a-p0121 min ert
7186c-p0121 min fails per test sample to set DTC
7186e-high TPS diagonostic max map
71870-low TPS diagnostic min map
71876-p0121 test sample size
71878-p0123 min fails per test sample to set dtc
7187a-p0123 test sample size
7187c-p0122 min fails per test sample to set dtc
7187e-p0122 test sample size
71880-p0123 min tps volts
71882-p0122 max tps volts
71884-high TPS diagnostic predicted TPS vs RPM
718a4-low tps diagnostic predicted TPS vs RPM
71e16-misfire max delta time-low rpm-cyl mode
71f48-misfire max delta time-mid rpm-cyl mode
7209c-misfire max delta time-high rpm-cyl mode
721ce-misfire max delta time-low rpm-rev mode
72300-misfire max delta time-mid rpm-rev mode
72454-misfire max delta time-high rpm-rev mode
725c8-misfire detection disable coolant temp
725ca-misfire detection enable coolant temp
725c5-misfire detection min ect coldstart
725d0-misfire detection coldstart ECT definition
725d2-misfire detection high rpm threshold
725d4-misfire detection low rpm threshold
725b5-firing order
72646-p0130 and p0150 min ect
7264a-p0130 and p0150 min ert
7264e-p0130 and p0150 rpm thresholds
72654-p0130 and p0150 airmass thresholds
7265c-p0130 and p0150 tps thresholds
72658-p0130 and p0150 ignV thresholds
7265a-p0130 and p0150 conditions enable time
72794-p0132 and p0152 min fails per sample to set dtc while in pe
72796-p0138 min fails per sample to det dtc whlie in pe
7279a-p0132 and p0152 test sample size while in pe
7279c-p0138 test sample size while in pe
727a0-p0132 and p0152 max o2mv in DFCO
727a1-p0138 max o2 mv in dfco
727a8-p0131 and p0151 min fails per sample to set dtc
727aa-p0137 min fails per sample to set dtc
727c0-p0131 and p0151 test sample size
727c2-p0137 test sample size
727c6-p0131 and p0151 max o2 mv
727c7-p0137 max o2 mv
727d8-p0134 and p0154 min fails per sample to set dtc
727da-p0140 min fails per sample to set dtc
727de-p0134 and p0154 max o2 mv
727df-p0140 max o2 Mv
727e2-p0134 and p0154 min o2 mv
727e3-p0140 min o2 mv
727e6-p0134 and p0154 test sample size
727e8-p0140 test sample size
727ec-p0131 and p0151 min fails per sample to set dtc while in pe
727ee-p0137 min fails per sample to set dtc while in pe
727f2-p0131 and p0151 test sample size while in pe
727f4-p0137 test sample size while in pe
727f8-p0131 and p0151 max mv while in pe
727f9-p0137 max Mv while in pe
72816-p0137 max Mv while in pe
72818-p0138 min fails per sample to set dtc
72822-p0132 and p0152 max o2 mv
72823-p0138 max 02 Mv
7282e-p0132 and p0152 test sample size
72830-p0138 test sample size
72b4a-fuel trim diagonostic minimum baro
72b4c-fuel trim diagnostic ECT thresholds
72b52-fuel trim diagnostic airmass thresholds
72b5a-fuel trim diagnostic minimum fuel level
72b5c-fuel trim diagnostic MAP KPA thresholds
72b60-fuel trim diagnostic IAT thresholds
72b68-fuel trim diagnostic intrusive mode airmass thresholds
72b70-fuel trim diagnostic intrusive mode min RPM
72b78-fuel trim diagnostic RPM thresholds
72b7c-fuel trim diagnostic maximum MPH
72bb6-idle diagnostic min baro
72bb8-idle diagnostic min ect
72bbe-idle diagnostic min IAT
72bc0-idle diagnostic IGNV thresholds
72bc8-idle diagnostic max TPS
72bca-idle diagnostic max MPH
72bda-p0101 EGR limits
72bde-p0101 max map
72be0-p0101 ignV thresholds
72be6-p0101 max airmass
72be8-p0101 max delta map
72bea-p0101 max evap purge percent
72bec-p0101 criteria enable time
72bee-p0101 TPS thresholds
72c1a-dtc fault type
72d0a-DTC fault enabled
72eec-egr disable run time vs start run coolant
72f3c-egr air temp disable
72f40-egr enable tps threshold
72f42-egr disable tps threshold
72f44-egr enable speed
72f46-egr disable speed
743a8-open loop af by RPM vs airmass
74784-Fuel level percent vs fuel level sensor volts
7482c-class 2 fan enable
74834-fan 1 ambient temp
74838-fan 1 coolant temp
7483c-fan 1 pressure
74840-fan 1 coolant vs vehicle speed
74844-fan 1 pressure vs speed
7484c-fan 2 coolant temp
74848-fan 1 keyoff coolant
7484a-fan 1 keyoff time
74850-fan 2 pressure
74854-fan 2 coolant vs speed
74858-fan 2 pressure vs speed
7486a-use filtered tps
7486b-WOT diables AE
7486c-disable tps closing delta
74870-AE TPS re-allow
74872-enable tps delta vs ect
748be-tps filter coefficient
748c0-AE disable ref count limit
748c2-AE modifier vs baro
748d6-AE MPH modifier
748e8-AE enrichment vs TPS max delta
74912-accel enrichment vs ref counts
74994-startup ae modifier vs ect vs ert-p/n
74aac-startup ae modifier vs ect vsert-in gear
74b56-closed loop desired a/f
74bc4-startup ae modifier ae vs tps.
74bda-startup ae modifier vs afr correction
74d48-open loop AF be rpm vs airmass ect threshold
75390-open loop base af by coolant temp
753b6-max startup ect for startup AFR coolant
753bc-max startup ect for startup afr coldstart
753fc-torque abuse a/f
753fe-torque abuse differential score a/d
75400-traction control desired a/f
7540e-over high MPH limit AFR
75410-rpm limit afr
75436-engine over temp a/f ratio
7546e-base PE a/f vs ECT
75494-pe rpm vs time a/f
755c6-PE a/f vs tps
755f2-Catalytic converter overtemp a/f ratio
75614-startup a/f enable time vs ect
75686-startup a/f adjustment by coolant temp
7587e-decay vs startupvs rpm-p/n
7590a-decay vs startup vs rpm-in gear
75a28-hot open loop fuel enable coolant temp
75a2a-hot open loop fuel disable coolant temp
75a30-hot open loop fuel IAT thresholds
75a34-hot open loop fuel MGcyl thresholds
75a38-hot open loop fuel MPH thresholds
75a3c-CAT protection coolant
75bde-engine runtime for cosed loop vs ECT
75c04-closed loop fuel enable coolant temp
75c06-closed loop fuel disable coolant temp
75c0a-closed loop fuel enable RPM
75c0c-closed loop fuel enable RPM time
75c12-pe mode delay rpm
75c14-rpm limit afr time
75c16-rpm limit afr threshold
75c18-pe delay vs tps
75c42-pe enable tps
75c64-pe enable cylinder mass air vs rpm
75c86-pe enable mass air threshold hysteresis
75c88-pe mass air enable threshole modifier vs baro
75ca6-torque abuse drive rpm
75caa-torque abuse drive injector disable
75cab-torque differemtial score injector disable
75cac-traction control # of injectors disabled vs tc mode
75cb8-traction disable injectors
75cc0-min rpm for MPH shutoff
75cc2-disable all injectors high MPH
75cce-disable 1 injector high MPH
75cd0-disable 2 injectors high MPH
75cd2-high RPM PN fuel cutoff
75cd6-high RPM REV fuel cutoff
75cda-high RPM fuel cutoff
75cde-DFCO disable TPS threshold
75ce0-DFCO enable coolant temp
75d00-DFCO enable/disable RPM threshold vs gear
75d16-DFCO disable vehicle speed
75d18-DFCO disable vehicle speed (cruise mode)
75dc6-de use filtered TPS
75dc8-disable positive tps delta
75dcc-enable negative tps delta
75dd0-de tps filter coefficient
75dd2-de disable ref count limit
75dd4-decel enlean vs TPS
75dfe-decel enlean modifer vs ref counts
75e3c-de modifier vs ect vs gear
75e64-de modifier vs vacuum
75e72-low pulse width injector offset vs pulse width vs map
75fea-prime pulse delay after powerup
75ffe-injector pulse boundary
76002-injector offset vs battery voltage
76062-end of injection pulse vs coolant temp
760bc-min evap purge percent
760c0-LTFT enleanment calc enabled
760c1-fuel trim cals use FTCO table
760c2-LTFT min ECT
760c4-LTFT max negative trim
760ec-LTFT offset for FTcell change
760fc-blm update enable coolant temp
760fe-STFT threshold needed to change LTFT
76106-max LTFT with maf failure
7610a-min LTFT with maf failure
76118-max LTFT with evap off
7611c-max LTFT with evap on
76120-min LTFT with evap off
76124-min LTFT with evap on
76128-FTC3 enable cylair
7612a-FTC3 disable cylair
7612c-FTC3 enable TP angle
7612e-FTC3 disable TP angle
76130-FTC3 enable RPM delta
76132-FTC3 disable RPM delta
76134-FTC1 disable cylair
76136-FTC enable cylair
76138-FTC disable TP angle
7613a-FTC1 enable TP angle
7613c-FTC enable MAF airflow rate
7613e-FTC4 disable MAF airflow rate
76140-FTCO disable RPM
76142-FTCO enable RPM
76144-FTCO disable TP angle
76146-FTCO enable TP angle
76148-FTCO disable mph
7614a-FTCO enable MPH
76156-FT learn min startup ECT
76158-ft learn min ERT
7615e-LTFT change vs rich/lean staus vs airmass
761ee-IFR lookup mode
76216-injector flow rate
76252-min injector pulse width
7625e-crank fuel vs RPM
762a8-crank fuel correction vs # ref counts
7636c-crank fuel correction vs crank RPM
763ae-crank fuel correction vs TPS
763ba-crank fuel correction vs baro
763ce-injector skew percent rough idle
763da-injector skew percent
7676a-base pulse width correction vs fuel pump flow
7678c-IPW correction vs IAT
768a6-2 speed fuel pump
768aa-fuel pump high speed disable ign volts
768ac-fuel pump high speed enable IGN volts
768ae-fuel pump high speed enable MAP
768b0-fuel pump high speed disable MAP
768b2-fuel pump high speed enable flow
768b4-fuel pump high speed disable flow
768be-fuel pump prime time
768c4-o2 sensor rich/lean threshold
768dc-STFT offset vs ftcell
76918-STFT offset engine cold ect max ect
7691a-max STFT
7691e-min STFT
76922-o2 sensor rich lean transition time at idle
76926-o2 sensor rich lean transition time vs airmass not idle
76938-base STFT table vs FTcell
769c2-CAT diagnostic enable coolant temp
769c6-o2 rich threshold offset min STFT
76bd9-enable bank 2 fuel trims
76bda-fuel mileage DIC readout multiplier
76bdc-hot light enable coolant temp
76bde-hot light disable coolant temp
76be6-IAC motor reset position vs baro
76bfa-IAC motor reset position offset vs ambient air temp
76c12-IAC airflow per step
76c54-IAC airflow correction vs oil temp
76c68-IAC airflow offset for fan 1 on
76c7a-IAC airflow offset for fan 2 on
76c7c-IAC airflow offset vs coolant temp vs ERT
76cd0-IAC airflow correction vs a/c pressure
76d02-IAC PN offset hi lo MPH threshold
76d04-IAC airflow offset for PN vs RPM
76d48-IAC airflow offset vs gear vs rpm
76e4a-IAC underflow dead band in PN
76e4c-IAC underflow dead band in drive
76e83-IAC overflow dead band vs % tPS
76f32-IAC correction for a/c snticipate vs a/c pressure
76f5e-IAC for a/c anticipate correctoin factor vs RPM
76fd4-IAC pn to drive added steps vs coolant temp
770f2-IAC rev to drive anticipate steps vs vehicle speed
7711c-IAC steps added for fan 1 on
7711e-IAC steps added for fan 2 on
77320-idle RPM offest vs baro
7738a-IAC desired idle RPM for trans not engaged
773d6-IAC desired idle RPM for trans engaged
775fe-throttle follower disable delay vs gear
7771c-throttle follower disable filter time constant vs ger
77d64-throttle follower gain factor vs vehicle speed
77ff9-use larger table steps
77ffa-MAP scaling factor
77ffc-MAP sensor offset
78000-defaul max map
780d4-default map vs tps vs rpm
7824a-default map vs ECT multiplier
78270-default map vs IAT multiplier
78296-default map vs egr multiplier
782ac-o2 sensor b2s1 present
78304-decel fuel cutoff spark advance
78306-warmup spark correction vs baro multiplier
7831a-low octane/bad fuel spark
785ba-high octane/good fuel spark
7885a-mean best torque spark
78afa-decel spark advance multiplier ve coolant temp
78b0e-decel spark advance multiplier vs ambient temp
78b22-decel spark advance vs RPM
78b3e-decel spark disable %tps
78b40-decel spark enable %tps
78b44-decel spark advance enable coolant temp
78b98-torque abuse spark
78b9a-max allowable spark advance
78b9c-min allowable spark advance
78ba0-min allowable spark advance- torque management
78bbe-egr spark advance correction vs load vs rpm
78cfe-egr spark advance correction vs load bs rpm, high alt.\
78e52-launch spark disable vehicle speed
78e56-launch sparnk enable pos delta TPS
78e58-launch spark enable pos delta mass air
78e5a-launch spark disable pos delta mass air
78e5e-launch spark diasble negative delta TPS
78e60-launch spark advance correction vs load vs rpm
78fda-launch spark correction multiplier vs coolant temp
79002-min power managment spark advance
79004 power management spark retard vs pm mode
79012-power managment spark retard adder vs pm mode vs tps
79106-spark advance p/n correction vs coolant temp
79140-tcc spark advance correction
792c0-AFR spark modifier
791c2-warmup spark correction vs load vs engine runtime
792d0-air temp spark modifier
79470-engine coolant temp spark modifier
796d6-high RPM threshold
796d8-high RPM spark
796da-egr spark modifier
79a50-idle spark enable coolant temp
78a52-idle spark disable coolant temp
79a78-idle spark advance vs load vs rpm
79acc-disable idle spark advance vs ect multiplier
79ace-idle spark advance multipliervs coolant temp
79b1a-closed loop idle spark correction afr-ap on
79b5e-closed loop idle spark correction AFR-ap off
79ba4-torque differential score retard
79ba8-high MPH limit
79bb6-warmup spark correction vs mph multiplier
79bc8-warmup spark max ert vs startup ect
79fec-min est signal high time
79fee-min est signal low time
79ff0-static dwell time vs reference period
7a03a-dwell time correction vs battery voltage
7a068-lower window limit dwell time multiplier vs rpm
7a08e-upper window limit dwell multiplier vs rpm
7a0b4-max main dwell table correction vs ign temp ve ign volt
7a280-max dwell time vs ign volt vs rpm
7a5ea-dwell time correction vs %egr
7a9cc-main dwell table correction vs ignition volt
7ab98-main spark dwell time vs ign volts vs rpm
7af10-burst knock disable RPM
7af12-burst knock disable MPH
7af14-burst knock detection min delta TPS
7af16-burst knock retard enable coolant temp
7af1c-max burst knock control
7af22-cyl air threshold
7af24-kncok retard recovery rate
7af46-knock retard decel recovery rate
7af68-knock retard IR attack rate
7af92-max allowed spark retard
7afa0-spark control runtime disable
7afa2-spark control coolant disable
7afa4-spark control rpm disable
7afa6-knock retard defaul value
7afb4-knock retard default max
7afc2-default KR vs MgCyl multiplier
7afe2-default KR vs rpm multiplier
7aff4-spark control map disable
7b124-traction mode boost control by torque
7b126-traction mode boost control disable
7b128-decel boost control MPH
7b12a-decel boost control by throttle
7b12c-integral gain
7b12e-porportional gain
7b130-boost ramp rate
7b132-excess MPH boost reduction gain
7b134-excess MPH torque reduction scalar
7b136-excess MPG enable timer
7b138-excess MPH enable by MPH
7b6e2-shift pressure 2nd base
7b724-shift pressure 3rd base
7b766-shift pressure 4th base
7b7a8-shift pressure 2nd performance
7b7ea-shift pressure 3rd performance
7b82c-shift pressure 4th performance
7b86e-2nd base pressure correction VS torque vs trans temp
7b918-3rd base pressure correction vs torque vs trans temp
7b9c2-4th base pressure correction vs torque vs trans temp
7ba6c-2nd downshift pressure correction vs torque vs trans temp
7bb16-3rd downshift pressure correction vs torque vs trans temp
7bbc0-4th downshift pressure correction vs torque vs trans temp
7bc6a-braking pressure 1st
7bc8c-braking pressure 2nd
7bcae-braking pressure 3rd
7bd90-2nd upshift pressure multiplier vs torque vs ratio
7be3a-3rd upshift pressure multiplier vs torque vs ratio
7bee4-4th upshift pressure multiplier vs torque vs ratio
7bf96-calculated pulses per revolution
7bf98-abuse mode duration vs trans temp
7bfdc-torque reduction 2nd to 1st downshift
7bffe-torque reduction 3rd to 2nd downshift
7c020-torque reduction 4th to 3rd downshift
7c042-torque reduction 1st to 2nd upshift
7c064-torque reduction 2nd to 3rd upshift
7c086-torque reduction 3rd to 4th upshift
7c0a8-torque reduction 1st to 2nd performance upshift
7c0ca-torque reduction 2nd to 3rd performance upshift
7c0ce-torque reduction 3rd to 4th performance upshift
7c130-1st to 2nd normal shift line
7c152-2nd to 3rd normal shift line
7c174-3rd to 4th normal shift line
7c196-2nd to 1st normal line
7c1b8-3rd to 2nd normal line
7c1da-4th to 3rd normal line
7c1fc-2nd to 3rd cruise shift line
7c21e-3rd to 4th cruise shift line
7c240-3rd to 2nd cruise shift line
7c262-4th to 3rd cruise shift line
7c284-1st to 2nd d2 normal line
7c2a6-2nd to 3rd d2 normal line
7c2a8-2nd to 1st d2 normal line
7c3c2-2nd to 3rd hot normal line
7c2ca-3rd to 2nd d2 normal line
7c2cc-1st to 2nd dlow normal line
7c2ce-2nd to 3rd dlow normal line
7c2d0-2nd to 1st dlow normal line
7c2d2-3rd to 2nd dlow normal line
7c3a0-1st to 2nd hot normal line
7c3e4-3rd to 4th hot normal line
7c406-2nd to 1st hot normal line
7c428-3rd to 2nd hot normal line
7c44a-4th to 3rd hot normal line
7c46c-1st to 2nd performance shift
7c48e-2nd to 3rd performance shift line
7c4b0-3rd to 4th performance shift line
7c4d2-2nd to 1st performance shift line
7c4f4-3rd to 2nd performance shift line
7c516-4th to 3rd performance shift line
7c538-1st to 2nd WOT shift
7c53a-2nd to 3rd wot shift
7c53c-3rd to 4th WOT shift
7c53e-2nd to 1st WOT shift
7c540-3rd to 2nd WOT shift
7c542-4th to 3rd WOT shift
7c544-1st to 2nd hot WOT shift
7c546-2nd to 3rd hot WOT shift
7c548-3rd to 4th hot WOT shift
7c54a-2nd to 1st hot WOT shift
7c54c-3rd to 2nd hot WOT shift
7c54e-4th to 3rd hot WOT shift
7c550-1st to 2nd performance WOT shift
7c552-2nd to 3rd performance WOT shift
7c554-3rd to 4th performance WOT shift
7c556-2nd to 1st performance WOT shift
7c558-3rd to 2nd performance WOT shift
7c55a-4th to 3rd performance
7c566-1st to 2nd shift RPM
7c568-2nd to 3rd shift RPM
7c56a-3rd to 4th hot shift RPM
7c56c-1st to 2nd hot shift RPM
7c56e-2nd to 3rd hot shift RPM
7c570-3rd to 4th hot shift RPM
7c578-1st to 2nd performance shift RPM
7c57a-2nd to 3rd performance shift RPM
7c57c-3rd to 4th performance shift RPM
7c584-1st to 2nd dlow urban line
7c5a6-2nd to 3rd dlow urban line
7c5c8-2nd to 1st dlow urban line
7c5ea-3rd to 2nd dlow urban line
7c85e-TCC apply 2nd normal line
7c880-TCC apply 3rd normal line
7c8a2-TCC apply 4th normal line
7c8c4-TCC release 2nd normal line
7c8e6-TCC release 3rd normal line
7c908-TCC release 4th normal line
7c92a-TCC apply 3rd cruise
7c94c-TCC apply 4th cruise
7c96e-TCC release 3rd cruise
7c990-TCC release 4th cruise
7c9b2-TCC apply 2nd hot
7c9d4-TCC apply 3rd hot
7c9fc-TCC apply 4th hot
7ca18-TCC release 2nd hot
7ca3a-TCC release 3rd hot
7ca5c-TCC release 4th hot
7ca7e-TCC apply 2nd performance
7caa0-TCC apply 3rd performance
7cac2-TCC apply 4th performance
7cae4-TCC release 2nd performance
7cb06-TCC release 3rd performance
7cb28-TCC release 4th performance
7cd5a-normal TCC release %tps threshold vs gear vs speed
7cdc0-cruise TCC release %tps threshold vs gear vs speed
7ce26-performance tcc release %tps threshold vs gear vs speed
7ce8c-1st to 2nd normal shift time
7ceae-2nd to 3rd normal shift time
7ced0-3rd to 4th normal shift time
7cef2-1st to 2nd performance shift time
7cf14-2nd to 3rd performance shift time
7cf36-3rd to 4th performance shift time
7d08a-shift switch type
7d08c-discrete switch debounce time
7d09a-IAT sensor present
7d09b-shift quality controled by pcm
7d0a5-trans torque reduction-master enable
7d0a6-trans abuse mode master enable
7d0e2-abuse control method
7d0e4-max turbine torque TCC locked
7d0fe-max turbine torque TCC unlocked
7d186-brake torque limit
7d2a0-torque abuse speed enable
7d2a2-torque abuse throttle enable
7d2a6-torque abuse rpm enable
7d2a8-torque abuse time enable
7d2b0-torque management engine speed limit
7d2b4-torque abuse spark retard
7d2e4-torque abuse differential score mph enable
7d33c-Catalyst protection boost shutoff
7d39c-traction control enable coolant temp
7d5e8-transmission type
7d5f2-1st gear min rpm/vehicle speed ratio
7d5fc-2nd gear min rpm/vehicle speed ratio
7d620-speedometer input pulses per revolution
7d634-pulses per mile
7d644-VTD present on car
7d64e-VTD injector disable time
7d654-VTD auto learn timer
7d65c-VTD auto learn counter
7d70e-tcc slip test fail slip rpm low
7d710-tcc slip test fail slip rpm high
7d734-tcc slip diagnostic disable rpm
7d736-tcc slip diagnostic enable rpm
7d9ae-max shift pressure
7d9b0-drive sproket ratio
7d9d4-first gear ratio
7d9d6-second gear ratio
7d9d8-third gear ratio
7d9da-fourth gear ratio
7d9dc-reverse gear ratio
7ea1a-trans abuse mode-min rpm
7ea1c-trans abuse mode-max trans rpm
7ea1e-trans abuse mode-min tps%
7ea22-trans abuse mode-max MPH
7ea24-trans abuse mode-torque reduction
7ee4e-downshift delay after tcc unlock
7eee4-tcc upshift unlock time vs gear
7eeec-tcc downshift unlock time vs gear
7effa-tcc dc max-line pressure vs trans temp
7f076-tcc dc min-line pressure vs trans temp
7f120-tcc pressure apply rate
7f9ce-FMC vs CLP vs temp-positive
7fb0e-torque step size for table lookup
7fbf4-trans revolutions per mile
7fffa-prom id
7fffe-programming complete pattern
1st class A**hole.
//www.fiero.nl/forum/Forum2/HTML/119122.html
