  Engine heat
Engine heat by Csjag
Started on: 01-13-2014 02:30 PM
Replies: 2 (187 views)
Last post by: James Bond 007 on 01-14-2014 08:33 PM
Csjag
Report this Post01-13-2014 02:30 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
How much more engine heat does the 2.8 have versus the 2.5 and is engine heat a problem with some of the popular swaps like the 3800SC?
Fiero84Freak
Report this Post01-13-2014 02:39 PM Click Here to See the Profile for Fiero84FreakSend a Private Message to Fiero84FreakEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero - and all the common popular swaps - is water-cooled so heat is not a problem in most occurences. The engine obtains operating temperature just like any other engine. The only time heat would be a problem is if you have some sort of problem with the cooling system itself, or it is inadequate for your current swap. For most V6 swaps the OEM cooling setup is fine. For some larger engines that not only take up room in the engine compartment but are also overall larger, normal cooling setups are inadequate.
James Bond 007
Total ratings: 263
Report this Post01-14-2014 08:33 PM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Its designed to run hot=less unburned fuel exiting the exhaust. The fan wont even kick on untill about 220+ degrees,
