  Lost Trunk Key
Lost Trunk Key by Hop
Started on: 01-13-2014 12:14 AM
Replies: 10 (193 views)
Last post by: Hop on 01-13-2014 02:16 PM
Hop
Report this Post01-13-2014 12:14 AM Click Here to See the Profile for HopSend a Private Message to HopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lost trunk key. Other than drilling out the lock, does anyone have a solution to opening the trunk lid when pushing the toggle switch on the dash will not release the lock?
jonathan2014
Report this Post01-13-2014 12:22 AM Click Here to See the Profile for jonathan2014Send a Private Message to jonathan2014Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are you sure you can open up the trunk. mine use to be that someone Had to hold up on the trunk while you push the button. I adjust the rubber bumpers and it worked right ever since.
Hop
Report this Post01-13-2014 12:32 AM Click Here to See the Profile for HopSend a Private Message to HopEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am sure that the lock is not releasing when the switch on the dash is pushed and I have misplaced / lost the key.
jonathan2014
Report this Post01-13-2014 01:28 AM Click Here to See the Profile for jonathan2014Send a Private Message to jonathan2014Edit/Delete MessageReply w/QuoteDirect Link to This Post
O well then drilling would be the best way that I can think of. Sorry for The misfortune
mitchjl22
Report this Post01-13-2014 05:05 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
no, take the switch out and jump the wires to open it.
gtoformula
Report this Post01-13-2014 12:47 PM Click Here to See the Profile for gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not the same key as used for the doors?
Hop
Report this Post01-13-2014 01:00 PM Click Here to See the Profile for HopSend a Private Message to HopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by mitchjl22: no, take the switch out and jump the wires to open it.
Thank You, will give that a try!
Hop
Report this Post01-13-2014 01:02 PM Click Here to See the Profile for HopSend a Private Message to HopEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hop
Member since Sep 2003
That is correct, not sure when it happened but when I got the car the door lock and trunk lock keys were different.
hdryder
Report this Post01-13-2014 01:13 PM Click Here to See the Profile for hdryderSend a Private Message to hdryderEdit/Delete MessageReply w/QuoteDirect Link to This Post
"The trunk release is hot at all times so you should be able to pop the trunk as long as you can get in the car. You need to have the parking brake applied for a manual car, or the shifter in Park for an automatic." (from: Bloozberry)
More information on rear lid latch below
https://www.fiero.nl/forum/A...502-2-085536.html#p0
[This message has been edited by hdryder (edited 01-13-2014).]
Report this Post01-13-2014 01:55 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you may have had something in the trunk that got between the latch and the hook, it will insulate the release from ground. Try inserting a similar key into the trunk lock. Clamp a jumper cable to the key then clamp the other end underneath to a portion of the frame and try the trunk release. I've seen that happen twice. Once with a shop cloth being laid on the latch hook and another with a plastic garbage bag.
Hop
Report this Post01-13-2014 02:16 PM Click Here to See the Profile for HopSend a Private Message to HopEdit/Delete MessageReply w/QuoteDirect Link to This Post
More information on rear lid latch below https://www.fiero.nl/forum/A...502-2-085536.html#p0
Thank You Sir, What a GREAT write up!!!
