  lower control arm bushings
lower control arm bushings by GR8_88
Started on: 01-12-2014 12:33 AM
Replies: 1 (454 views)
Last post by: GR8_88 on 01-12-2014 09:01 AM
GR8_88
Report this Post01-12-2014 12:33 AM Click Here to See the Profile for GR8_88Send a Private Message to GR8_88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Im replacing the lower control arm bushings on my 88gt with new rubber ones and have a couple questions. Are both bushings in one control arm the same? They look the same but I have read that there was a different part number for the front vs the rear in some older posts. Now I have two replacements (470722 GM part number) can I just use them or do I need to search for another? Also I noticed that the new bushing inner sleeves have jagged or serrated outer ends, Why? Is it necessary or can I grind them down?
Thanks
GR8_88
Report this Post01-12-2014 09:01 AM Click Here to See the Profile for GR8_88Send a Private Message to GR8_88Edit/Delete MessageReply w/QuoteDirect Link to This Post
anyone?
