  Poly vs Solid?
Poly vs Solid? by tebailey
Started on: 01-09-2014 09:16 PM
Replies: 7 (280 views)
Last post by: NetCam on 01-11-2014 11:13 PM
tebailey
Report this Post01-09-2014 09:16 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a rebodied 84 4speed, and wanted to ask is it worth $50 more for the solid cradle bushings over the poly for a car that will only get an occasional summer cruise?
IMSA GT
Total ratings: 250
Report this Post01-09-2014 09:21 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Less to wear out but possibly more engine noise in the cab and vibration.
wftb
Report this Post01-09-2014 11:41 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
poly is a waste of time .why the engine cradle has rubber mounts is beyond me .you can not hear any extra road noise with the solid mounts vs poly. i have had both on my car . the noise you hear is the same because all your suspension mounts are rubber (or poly if you have switched them too) . the 88's came from the factory with solidly mounted cradles .
Blacktree
Total ratings: 350
Report this Post01-10-2014 12:02 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Personally, I think the solid cradle bushings are worth the price premium. But I may be a little biased. My '87 Fiero has had solid aluminum cradle bushings since 2004.
jb1
Report this Post01-10-2014 03:35 AM Click Here to See the Profile for jb1Send a Private Message to jb1Edit/Delete MessageReply w/QuoteDirect Link to This Post
If I had it to do over or change them om another I will go solid cradle bushings.
(series II swap in progress)
85GT Northstar/ 4t80e
86GT 3800 n/a
Northstar Rebuild
tebailey
Report this Post01-10-2014 09:57 AM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nuff said, solid it is. Thanks.
stickpony
Report this Post01-11-2014 10:47 PM Click Here to See the Profile for stickponyClick Here to visit stickpony's HomePageSend a Private Message to stickponyEdit/Delete MessageReply w/QuoteDirect Link to This Post
i disagree, the vibration is noticeably less with poly bushinsg vs solid, but the ride is still more stiff than stock rubber... just my opinion
NetCam
Report this Post01-11-2014 11:13 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
Solid may provide a bit more vibration, but will eliminate sloppy cradle movement in corners.
