  Fuel pressure gauge
Fuel pressure gauge by LornesGT
Started on: 01-04-2014 09:35 PM
Replies: 1 (389 views)
Last post by: cmechmann on 01-04-2014 10:00 PM
LornesGT
Report this Post01-04-2014 09:35 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is there any reason to not use an oil pressure gauge for testing fuel pressure? It hasn't been used for the oil test yet.
cmechmann
Report this Post01-04-2014 10:00 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
As long as it don't have plastic parts inside. Some cheaper ones have a plastic expansion bulb inside. If it is the brass type bulb OK. A little tricky, but the better ones can be opened. Take the View cover off, remove screws on back(normally 2).
Also make sure you use hose and seals that can tolerate fuel/ethanol.
